2005 BMW 525i E60
I have a 2005 BMW 525i E60 ,the radio sound cuts on &
off when car temperature is higher than 29 degrees also the Idrive display goes off and comes back on . This has been getting worse as the weather gets hotter. The battery is checked and is fine , the CD player is working fine. Can any one give a suggestion as to where I can locate the problem? Does anyone have a diagram or know of a youtube segment that will help me locate and fix this problem it would be greatly appreciated.
My Ride: 08 LCI 535i sport M5 umnitza full kit, Maya RM 1 245/35/20 20x9 et16, 275/30/20 20x10.5 et17, Future mods- KW coilovers V3 and StopTech brake
There might be a bad ground wire.
My Ride: 2006 BMW 550i
could also be the amplifier that is mounted in the trunk....left side behind carpet panel. not sure though if you'd have an amp if you have a standard stereo though.
SFx550i
04-14-2015 05:00 PM
turbogate
04-11-2015 05:02 PM
BYS2
03-24-2015 03:13 AM
