12V
My Ride: E61 525iA Build 2004/08. "Safirschwartz Metallic". Navi Pro, Adaptive Headlights, Bi-Xenon, Panorama Sunroof etc... CIP 18.00.01 (No noticed bug)
Hello,
I'm looking for a 12V source somwhere in the left front (steering) part of my E61. What I need is a 12 V "always hot" and a 12 V ignition dependent hot (no big amps at all).
I know that the cigarette lighter provides an ignition dependent hot, but how on earth do you get behind consoles & panels?
My Ride: 545i Sport Auto (see sig)
Originally Posted by stafli' date='Oct 9 2005, 01:29 AM
Hello,
[snapback]181617[/snapback]
http://www.gbxdirect.com/store/special_tools.php
Plus you'll need an electric screwdriver and Torx bits.
It's not as hard as you think. The #1 rule is NOT TO FORCE ANYTHING. If a particular piece isn't coming off easily, you're either not yanking it at the right angle or it's still connected with a clip or screw you missed. Also bring lots of towels to cover up things with so you don't scratch trim.
Before you do anything to the electrical system please put aside an evening and read through this website:
http://www.bcae1.com/
You may save yourself from burning down your car.
Hello
Did you ever find out where to get an ignition dependant hot and an 'always hot' source? I need to get the same to install my SmartNav and am not sure where to get the 'always hot' source.
Thanks
Colin
Thanks
Colin
Originally Posted by stafli' post='181617' date='Oct 9 2005, 08:29 AM
Hello,
My Ride: G30 M550i
Model Year: 2018
I can't recall if anyone ever found a way to tap into an always hot power source -- something tells me it's going to be difficult since the car has a sleep mode where just about everything shuts down.
If someone has accomplished this, I'm sure we'll get some replies. If not, I'm thinking that you'll need to either tap into the parking lights or hazard lights circuit or run a wire directly from the battery instead.
My Ride: F02 LCI Individual
Model Year: 2013
My dealer installed an "alleways hot" power outlet for me.
He connected it somewhere behind the glove box, but had to install an insulating diode (I hope this is the correct word... ) too, because w/o it the high battery drain warning would allways come up.
My Ride: F11 520d white, auto, professional sat-nav with internet, variable damper control, sports steering wheel, extended lighting, retractable tow bar, wing mirrors with dimming & folding, full electric seats with memory & lumber adjustment, etc.
<_< Can someone advise where I can get 12v to add a power socket in the trunk / boot of car? BMW UK do not provide as standard power sockets in the rear or trunk / boot on SE spec cars which is astounding for a vehicle costing ? 38K
thanks
thanks
My Ride: G30 M550i
Model Year: 2018
My car came with a 12V socket in the trunk. If your car doesn't have one, I imagine you could get this retrofitted or do it yourself...
Look at part number 3 & 4 of the following:
http://www.realoem.com/bmw/showparts.do?mo...331&hg=61&fg=35
On my car, the outlet comes through part number 25 in the following diagram:
http://www.realoem.com/bmw/showparts.do?mo...126&hg=51&fg=65
Model Year: 2013
thanks
thanks
Location: Europe, Netherlands, Near the (German) Autobahn
My Ride: 525d E60
I just mounted a non-BMW factory socket in the boot (at the space where BMW mounts it too) that was easy enough.
I found a wire going from the plus to the minus pole of the battery. Any idea what that does??
Now I need to get a cable from the boot to the shelf under the rear window...... that's a challenge too!!
My Ride: 525d E60
no battery drain messages or anything like that.
