'06 e60 sucessful halogen to oem bi-xenon swap
Old 10-26-2009, 06:07 PM
  #31
AKAlius's Avatar
Originally Posted by mtrinh1' post='751895' date='Dec 24 2008, 03:17 AM
After reading many forums I've finally completed putting in oem bi-xenons into my e60 which came with stock halogen lamps (no adaptive headlights). Many of the steps were scattered throughout the many posts so I've put together the complete steps to save you guys time. First off, if you have the time and money, it was well worth the swap, total costs including parts and supplies were around $875, could've been less but i got kinda ripped off from the guy that sold me the lights. (told me it was complete with ballasts, bulbs and igniters, false! didnt come with anything)
1) cut the green wire coming from the socket in half (xenon light beam adjust feed), splice the end from the socket to the gray wire (angel eye wire, to get rid of error message) cause theres only one angel eye bulb.
2) connect the other end (the end going to ur xenon lights) of the green wire to the white wire (high beam feed) this would make your bi-xenon highbeams work.
3) splice the two fat brown wires coming from the socket together to give ur ballast ground
4) get a 4700uf 35v capacitor, connect the negative end to the brown wire and positive end to the yellow wire going to your ballast (gets rid of strobing effect and error messages)
if you dont want highbeams skip step 2, all this should take u nomore than an hour, took me two days to sort everything out lol...
hope this helps, well worth the trouble... also this is only for an e60 that came with no projector halogen lights.
seriously doubt i can make the adaptive feature work...
Last step....have fun adjusting the lights lol, took me awhile....
Hope this helps..
p.s. don't let the dealer see the inside of ur headlight capsule lol...bye bye waranty.....
Nice DIY! I'm sure many members will find this very useful. Thanks Trinh!
Old 10-26-2009, 09:39 PM
  #32
jas_r_1's Avatar
My Ride: 2006 520d - 19" 172s- Remapped - LCI taillights V6 cables - LCI xenon headlights - Denison 500 with BTA1500 - led interior lights - OEM led number plate lights Planned mods: Folding mirrors - Modmynav kit - High gloss shadowline trim -
Originally Posted by machy' post='1040955' date='Oct 27 2009, 01:10 AM
Anyone have any suggestions where to get a retrofit kit to do this? You guys recommend replacing the existing lights with xenon projectors or should i just replace the whole headlight? Found tons of different ballasts and ignitors... any suggestion which works best?
Thanks...
Mike
+1
Old 11-04-2009, 03:35 PM
  #33
530iM's Avatar
My Ride: 2003 BMW 530i M sport
Ive bin trying to do this for donkey years lol
ps would this work on a 2003 car?
thanks
Old 11-05-2009, 09:44 AM
  #34
530iM's Avatar
Just did this today and it works!!!!!!!!!!!!
only took me about a hour and a half
The only thing wrong is one of the beams is too high and one is too low but other than that it all good (anyone know how to adjust them? )
Thanks
Old 11-05-2009, 10:28 AM
  #35
bruce_miranda's Avatar
If any one want plugs from the BMW OEM retrofit kit just contact me. I have some remaining from when I used to use the LCI conversion kits to get the rear plugs.
Old 11-11-2010, 09:12 AM
  #36
cantosman's Avatar
Can i use this setup even if i dont have bi-xenon? I only got xenon on low beams
Old 11-12-2010, 12:38 AM
  #37
NguyenAzn's Avatar
My Ride: 525i
any detail set up pics ? cuz im a rookie on wiring these things
Old 11-12-2010, 05:56 AM
  #38
BlaSTiWi's Avatar
Detail diagram up on post #23 and some sample pics on post #18 on pg. #2.
Old 07-31-2012, 10:51 PM
  #39
tarlai's Avatar
My Ride: E60 Carbon Black 02/2006 Sport
Hey guys ... I am done with Pre LCI Halogen > LCI Xenon (non adptive) Conversion on my 2006 530i sport ... BUT, I did it a little different, therefore got stuck with a few things
Things I have done so far:
1. Installed LCI Bi-Xenon (non adaptive) headlights and LCI Tail Lights.
2. Used BMW Genuine Retrofit Cabling
3. I followed the same Wiring Diagram (Halogen to Xenon) as provided by "Milko75" in this thread.
4. Plus I installed LM2 (thats the extra bit), changed VO (added #0906 and $522) and programmed LM2 as per new VO.
5. Due to LM2 and coding, I didnt need capacitors and lights are stable, no flickering
6. High beam, low beam, eye brows and rear lights work fine
Current Issues:
1. Parking lights go off after 5-6 seconds
2. Indicators flah too fast
3. iDrive is full of errors, no single light is functional as per the iDrive
Do you guys have any clue how to get rid of these issues
Any will be highly appreciated. Cheers!
Old 08-08-2012, 01:50 AM
  #40
tarlai's Avatar
Anyone on the above request pleassssseeeee ???
Quick Reply: '06 e60 sucessful halogen to oem bi-xenon swap
