A Tale of Two Wheels
Last week my Rejex arrived and I treated my left wheels with Rejex and skipped the right wheels. After 4 days of driving, some on wet streets, I cleaned the wheels again. Both wheels cleaned easy enough with water only. Before washing, the treated wheel did not look quite as bad as the untreated wheel, but I would not recommend using Rejex as a means to simplify wheel cleaning.
Now for the rest of the car, the sheen was absolutely brilliant. Remember, this is a light colored car. If I had a dark colored car, I would be tempted to experiment with Rejex versus a several stage process. The car rinsed easily with a quick sponge and no soap. The finish is slick to the touch like a freshly waxed car.
Below are the two front wheels before rinsing.
My results for Rejex were outstanding for paint on Titanium Silver. Ease of application is a big plus.
I tested on wheels and found it less than satisfactory as a solution to brake dust.
Sorry for the miscommunication.
Originally Posted by heezy545i' date='Jun 7 2004, 05:26 PM
As a wax on the paint, how does it compare to other things you've used?
madein
06-06-2015 11:48 AM
Virak1985
06-02-2015 11:16 PM
