Selling Flex 3401
Originally Posted by kaiten408' post='975567' date='Aug 13 2009, 03:35 PM
But the FLEX is supposed to be stronger and smoother, the PC runs up to 6800 OPM and the flex goes up to 9200 opm, IIRC
My Ride: I have an 05 545i. It's a manual with a few options. This is my first BMW but I don't know how I'll ever be able to switch to something else.
hmm............well I would have to say that either you didn't use a 3401 (dunno what else you would have used) or maybe you just 'thought' it wasn't going up to 9K OPMs.
the FLEX is suppose to be alot quieter and smoother (less vibration) than the PC, which i could see leading you to think it wasn't as fast?
Here's a good video of comparing them, same pads & same polish
FLEX vs PC video
FLEX vs PC video
I saw that vid also, for me personally I thought it was a little too akward and heavy. I will say this the gear drive in it is nice and the uh progressive trigger i guess you call it...you set your max and then you can polish from low to your max...you dont have to keep switching speeds. Again for me personally I like the CCS 5.25 pads at 4-5 opm.
Remember its not the size, but how you use it
Enjoy it Kaiten!
FLEX vs PC video
FLEX vs PC video
Hmmm I guess its possible, but I remember reading the big FLEX logo on it hahaha and then reading the specs and it only showed up to 6xxx max. The flex is smoother but I'm assuming b/c it doesn't "orbit" like the PC does.
Anyways....lets not digress from the celebration of your new polisher!!!!
I will Adam! I'll be sure to let you guys know how it goes. I'll probably get a detail in next wednesday or thursday. I have 2 test in organic chemistry next week so i'm going to be busy for the next few days
I sent you as I said CG Revive Polish, Final Polish and......the EZ Creme Glaze which smells great and acts like a wax, well you can use it as a prewax or sealeant. I am hoping I gave you enough of each sample. You should have enough to test on the hood.
White pad- all polishing
Blue pad- final polish
Red pad- glaze/sealents/ waxing
yellow pad- really really pad swirls etc..I never had anything that bad
you should have it tuesday!
Thanks Adam! I'm looking forward to using this on my car, i've never given her a proper polish.
Thanks again adam, it was a pleasure doing business with you.
See you on the forums!
Received the package today, everything was packed well and is in working condition.
Thanks again Adam
I'll be letting you guys know how it goes later this week.
Thanks again Adam
jcolley
10-14-2015 08:04 AM
