removing wheel weight glue/paper
My Ride: 06 530i Premium and Cold Weather Package
Orient Blue, Tan Interior
Get any plastic item with a relatively pointed (not really sharp or you will scratch or remove clear coat) end and scrape it off. Also helps to hit it with wheel cleaner and let it dry out first.
Soften the adhesive with some googone or WD-40. Best if you saturate a folded up paper towel and lay it on the exact spot for a few minutes to allow it to soak in and soften the glue before scraping off with a piece of plastic (old credit cards are perfect for the task).
chadillac2000
42
09-13-2017 11:15 AM
jwdominick
05-19-2015 02:50 PM
