My is almost a year old with 12.5k miles. I have always washed my car and used a wheel cleaner. Recently switched to the PS1(or os it PS2) gel because you can leave it on longer. But I can't get the spots that seemed to be glued to the rim off. Any suggestions?
Try some Stoner "Tarminator" or some type of Clay product for removal of surface contaminants
Dave www.innovativedetailing.com |
Try a good car wax first. It may be enough to get the job done.
Thanks, will try less agressive stuff first then move up.
I have the same problem with hard to remove spots on the inside of the rims. I don't even know what the dirt is. No one can see those spots but I know they're there and they'll keep building up over time so I'd like to remove them, atleast a majority of them somehow. Since I'm putting the spring tires back on in the next week or so it'll be a good time to do so. I'll try the tarminator stuff which I found for 6 bucks at the URL below:
http://www.autogeek.net/tarminator.html |
Lomag, Let me know how it works. You can easily see my spots, they are black and obviously brake dust. My car is usually clean and I always use a wheel cleaner. I do drive pretty fast and am hard on the brakes. But my car is only a year old so I need to find a way to keep them clean.
Try using Clay Magic--works great. Also is great for getting a super smooth finish before waxing the paint. I clay every 6 months (use a separate bar for the wheels!).
http://www.autopia-carcare.com/awc-88256.html Then apply some Rejex--it will minimize the amount of brake dust that sticks to the wheels. http://www.corrosionx.com/rejex.html |
Another suggestion is to use autoglym super resin polish applied with a microfibre cloth .The solvent in the polish is great for tar spots and good on brake dust/spots also as above adding the polish also cuts down on future cleaning
Bill. :thumbsup: |
dunno if this is obvious to everyone...if you use a claybar to do your wheels, DO NOT then use it on your cars paint. brake dust is a killer. better to just throw it out or use it ONLY for wheels in the future.
