How to keep trunk clean?
Hey guys, do any of you have suggestions as to how to keep the E60's trunk really clean. We will often have golf clubs, for example, in the car and want to keep the car clean. Is there anything that can be bought that will keep it clean and look right for the car?
Hope that's not vague.
Thanks,
-AJ
Thanks,
-AJ
My Ride: G30 M550i
Model Year: 2018
The trunk mat is reversible. You might want to use the back side which is rubberized. It prevents things from sliding around and I'm sure it's more washable.
I also thought I remember seeing something in the BMW accessories catalog like a trunk liner. (I might have imagined it though!)
Originally Posted by sj3' date='May 29 2004, 08:15 PM
small vacuum cleaner in maybe the netted compartment. Very easy to plug in in the trunk so can be used very quickly.
I went to Home Depot and picked up a small roll of outdoor carpeting, took out the trunk liner from the car and put it on top of the carpeting. I then used a magic marker and and used the liner as a template. I also made a paper template of the small shelf area to the right and left of the trunk opening. I cut the carpeting and put it on top of the original liner. Now I can throw anything in the trunk. I also have the option of removing the carpeting to clean it or use the original liner as I see fit.
slow.motoren.werke
DIY: Do It Yourself
Aug 25, 2015 03:46 PM
DetailersDomain
Detailing Forum
Aug 5, 2015 05:17 PM
