Forum members 5 series detail job
I detailed one of this forum members 5 series and thought you would enjoy seeing the process and end results. I have to say the owner was a very nice guy and took awesome care of his car and had a few really nice improvements such as led lighting and he also debadged the car.
I forgot to take before pics and did not take any until after I washed and clayed the car. I always use QD as clay lubricant so it tends to add a little shine to the finish. Luckily the owner snapped a few so here they are.
I tried to capture some of the problem areas but this is an area that I am not real good at. For some reason when I take pics the car always looks better than it really is. The entire top of that door had horrible scratches all the way across. You can barely see it a little bit by my finger. I was on a tight schedule so I concentrated more on detailing the car than I did trying to get great pics. Priorities...
I also clayed the car. It was incredibly rough but the clay was not as dirty as I expected.
A poor attempt at a 50/50 shot. Bad side looked much worse in person. Car was all taped up and ready for the paint correction at this point.
A scrape that was touched up.
I pulled it outside after polishing to inspect and note areas that needed more attention.
Well, on to some after shots but before that I will outline what products I used.
I used Zaino Clay and Chemical Guys QD for a clay lube.
Polishing was done with a Flex 3401 and a green LC pad using Menzerna P085rd. The bad areas was done with a rotary and 3M polish first.
I used Conneusors Choice on the plastic interior trim and Zaino Z10 on all the leather surface. I also used Z16 on all rubber surfaces such as weatherstripping and tires etc.
After a Dawn wash I used ZAIO followed by Z5p. That was then finished with a combo of Z6 to remove any excess Z5p and Z8 to give it that little extra POP.
My Ride: Mach5 05' 530i Black Sapphire Metallic w/Auburn Leather Seats, Heated Front/Rear Seats, Cold Weather Pkg, Premium Pkg, Sports Pkg, Xenon Headlights, NAV, Mud Flaps, 20" 166 Style Rims
Model Year: 2005
Engine: N54
I have to say I was pleasantly surprised at the results considering the vehicle has over 100K miles on it. It came out beautiful. Thanks again Frank.
My Ride: 2007 525xi led ae's, magnaflow exhaust, k&n filter, carbon filter delete, 19" BBS LM-R. Sprint booster, black tails, euro fresh headlight decals.
I have a black sapphire as well, can I drop it off to u?!
