Edge pads
My Ride: 2003 Audi RS6/2002 Porsche 911 Turbo/2007 Toyota FJ Cruiser
Originally Posted by pyiu' post='519698' date='Jan 18 2008, 03:01 PM
Thanks Piyu,
I have a question for you, what is the difference between cutting, compounding, polishing and glazing?
I can imagine that glazing will be to add shine to the car, but im confused about cutting and polishing, isn't it the same, cutting removes swirls and so does polishing?
Originally Posted by rjcastr' post='519704' date='Jan 18 2008, 03:12 PM
Thanks Piyu,
cutting would be for agressive polishes like SIP
polishing would be for final polish like 85rd
glazing for glazes after the final polish (not necessary)
My Ride: 2007 E60 530i
Color: Jet Black/Black Anthracite
STEP | Sport | Premium | NAV | Logic 7
EXTERIOR:
M-Tech Kit | M5 Mirrors, Trunk Finisher | Jet Black Kidney Surrounds | Madico Charcool Tint 54%, 35%
LIGHTING:
Euro-Headlights | Euro-LCI Tail Lights | AiB V3.0 | Solaris Invisi-bulbs | OEM LED Plate Lights
PERFORMANCE:
Porterfield R4-S Brake Pads | K&N Air Filter
WHEELS & SUSPENSION:
Work VS-XX 20x9, 20x10 | Toyo T1R 245/30/20, Michelin Pilot Sport A/S 295/25/20 | KW V2 Coilovers | Rogue Engineering 15mm Spacers
I'm thinking about picking up a FLEX polisher. As this will be my first DA/RO purchase, I'll also need some backing plates, pads and polish. What size pads and colors do you guys recommend?
My paint is in pretty good shape and has minor spiderwebbing from normal wash, so I don't think I would need that intensive of a polish. I was thinking MENZERNA PO106FF for the paint.
But I bought some used Euro-headlights that need some major correction. I already have Meguiars's PlastX, do I need a more intensive polish?
Please help. Thanks!
I should have some flex in 3-4 weeks back in stock.
6.5 inch ccs pads would be a great start.
as for a backing plate the flex has its own backing plate so you won't need one.
EXTERIOR:
LIGHTING:
PERFORMANCE:
What color pads/cutting power do you recommend I pickup?
Do I need smaller pads for the headlights and other areas like the license plate?
How do you polish underneath the door handles?
polish the door handles by hand.
with the flex the smallest pads are 5.5 inches.
Here is the pad kit:
http://www.detailersdomain.com/index.asp?P...&ProdID=175
