CRAP!!
Old 04-27-2009, 10:19 AM
  #21
Brit_in_NJ's Avatar
My Ride: '05 545 Titanium Silver, Black Leather - Nav, Logic 7, Cold weather. Mods: Carbon filter removed. M5 iDrive knob. Umnitza license plate LEDs. MP3 40% 3M tint ACS Anti-Roll(sway) bars RPI Scoop G-tech Pro RR CF Roundels CF Wheel caps
Originally Posted by craigm1841' post='860314' date='Apr 27 2009, 11:41 AM
+1
BTW, What's the air speed velocity of an unladen swallow?
Old 04-27-2009, 10:23 AM
  #22
sdg1871's Avatar
My Ride: See my signature
Originally Posted by flyingpuck' post='860484' date='Apr 27 2009, 02:03 PM
Amen!! How about them Lakers??!!
How about that President Obama honoring the Connecticut Lady Huskies for their championship?
Old 04-27-2009, 10:24 AM
  #23
sdg1871's Avatar
Originally Posted by Brit_in_NJ' post='860496' date='Apr 27 2009, 02:19 PM
+1
You guys are incorrigible.
Old 04-27-2009, 10:26 AM
  #24
Brit_in_NJ's Avatar
haha..back on topic I have all of my detailing stuff in the trunk of the car...its under a tree every night
Old 04-27-2009, 10:31 AM
  #25
unknown's Avatar
is it an african or european swallow?
Old 04-27-2009, 10:34 AM
  #26
Brit_in_NJ's Avatar
Huh? I don't know that. Auuuuuuuugh!
Old 04-27-2009, 10:38 AM
  #27
unknown's Avatar
http://www.youtube.com/watch?v=y2R3FvS4xr4
How do know so much about swallows?
Old 04-27-2009, 10:48 AM
  #28
Brit_in_NJ's Avatar
Well you have to know these thing's when your a king you know....
and back on topic I think a family of them live in the tree above my car!
Meguiars Quik Detailer and MF cloth (not the Samuel L. Jackson type) But I've also used some multi-surface wipes when the craps real bad.
Old 04-27-2009, 11:13 AM
  #29
JeffNNJ's Avatar
My Ride: 2011 M3 Convertible, Alpine White/black, 6 speed 2011 535xi Tasmin Green, Venetian Beige
Originally Posted by unknown' post='860310' date='Apr 27 2009, 11:40 AM
jeffnnj- nice meeting you and your son @ bear run. i think this was your first time out? did the run meet your expectation?
Was our pleasure, thanks. We both thought it was great. We'll definitely attend the next one.
Old 04-27-2009, 11:20 AM
  #30
craigm1841's Avatar
+1
you guys should know better by now. being the google king coupled with my sarcastic diposition, should have know this was coming...
To begin with, I needed basic kinematic data on African and European swallow species.
South African Swallow
(Hirundo spilodera) European Swallow
(Hirundo rustica)
Although 47 of the 74 worldwide swallow species are found in Africa,1 only two species are named after the continent: the West African Swallow (Hirundo domicella) and the South African Swallow (Hirundo spilodera), also known as the South African Cave Swallow.
Since the range of the South African Swallow extends only as far north as Zaire,2 I felt fairly confident that this was the non-migratory African species referred to in previous discussions of the comparative and cooperative weight-bearing capabilities of African and European swallows.3
Kinematic data for both African species was difficult to find, but the Barn or European Swallow (Hirundo rustica) has been studied intensively, and kinematic data for that species was readily available.
It?s a simple question of weight ratios
A 54-year survey of 26,285 European Swallows captured and released by the Avian Demography Unit of the University of Capetown finds that the average adult European swallow has a wing length of 12.2 cm and a body mass of 20.3 grams.4
Because wing beat frequency and wing amplitude both scale with body mass,5 and flight kinematic data is available for at least 22 other bird species,6 it should be possible to estimate the frequency (f ) and amplitude (A) of the European Swallow by a comparison with similar species. With those two numbers, it will be possible to estimate airspeed (U).
In order to maintain airspeed velocity, a swallow needs to beat its wings forty-three times every second, right?
Actually, wrong. By comparing the European Swallow with bird species of similar body mass, we can estimate that the swallow beats its wings 18 times a second with an amplitude of 18 cm:
Species Body mass Frequency Amplitude
Zebra Finch 13 g 27 Hz 11 cm
European Swallow 20 g ≈ 18 Hz? ≈ 18 cm?
Downy Woodpecker 27 g 14 Hz 29 cm
Budgerigar 34 g 14 Hz 15 cm
Note that even the tiny Zebra Finch flaps its wings no more than 27 times a second while cruising.
If we ignore body mass and look only at bird species with a similar wingspan, we can estimate an average frequency of 14 beats per second and an amplitude of 23 cm:
Species Wingspan Frequency Amplitude
Budgerigar 27 cm 14 Hz 15 cm
European Swallow ≈ 28?30 cm ≈ 14 Hz? ≈ 23 cm?
Downy Woodpecker 31 cm 14 Hz 29 cm
European Starling 35 cm 14 Hz 26 cm
By averaging all 6 values, we can estimate that an average European Swallow flies at cruising speed with a frequency of roughly 15 beats per second, and an amplitude of roughly 22 cm.
Skip a bit, Brother
Last month?s article on The Strouhal Number in Cruising Flight showed how simplified flight waveforms that graph amplitude versus wavelength can be useful for visualizing the Strouhal ratio (fA/U), a dimensionless parameter that tends to fall in the range of 0.2?0.4 during efficient cruising flight.
For a European Swallow flying with our estimated wingbeat amplitude of 24 cm, the predicted pattern of cruising flight ranges from a Strouhal number (St) of 0.2:
... to a less efficient 0.4:
If the first diagram (St = 0.2) is accurate, then the cruising speed of the European Swallow would be roughly 16 meters per second (15 beats per second * 1.1 meters per beat). If the second diagram (St = 0.4) is accurate, then the cruising speed of the European Swallow would be closer to 8 meters per second (15 beats per second * 0.55 meters per beat).
If we settle on an intermediate Strouhal value of 0.3:
We can estimate the airspeed of the European Swallow to be roughly 11 meters per second (15 beats per second * 0.73 meters per beat).
Three shall be the number thou shalt count
Airspeed can also be predicted using a published formula. By inverting this midpoint Strouhal ratio of 0.3 (fA/U ≈ 0.3), Graham K. Taylor et al. show that as a rule of thumb, the speed of a flying animal is roughly 3 times frequency times amplitude (U ≈ 3fA).5
We now need only plug in the numbers:
U ≈ 3fA
f ≈ 15 (beats per second)
A ≈ 0.22 (meters per beat)
U ≈ 3*15*0.22 ≈ 9.9
... to estimate that the airspeed velocity of an unladen European Swallow is 10 meters per second.
Oh, yeah, I agree with that
With some further study, it became clear that these estimates are accurate, though perhaps coincidental.
An actual study of two European Swallows flying in a low-turbulence wind tunnel in Lund, Sweden, shows that swallows flap their wings much slower than my estimate, at only 7?9 beats per second:
?Compared with other species of similar size, the swallow has quite low wingbeat frequency and relatively long wings.? 7
The maximum speed the birds could maintain was 13?14 meters per second, and although the Lund study does not discuss cruising flight in particular, the most efficient flapping (7 beats per second) occurred at an airspeed in the range of 8?11 meters per second, with an amplitude of 90?100? (17?19 cm).
And there was much rejoicing
Averaging the above numbers and plugging them in to the Strouhal equation for cruising flight (fA/U = 7 beats per second * 0.18 meters per beat / 9.5 meters per second) yields a Strouhal number of roughly 0.13:
... indicating a surprisingly efficient flight pattern falling well below the expected range of 0.2?0.4.
Although a definitive answer would of course require further measurements, published species-wide averages of wing length and body mass, initial Strouhal estimates based on those averages and cross-species comparisons, the Lund wind tunnel study of birds flying at a range of speeds, and revised Strouhal numbers based on that study all lead me to estimate that the average cruising airspeed velocity of an unladen European Swallow is roughly 11 meters per second, or 24 miles an hour.
What is the capital of Assyria?
For those looking for additional answers, the four capitals of Assyria were Ashur (or Qalat Sherqat), Calah (or Nimrud), the short-lived Dur Sharrukin (or Khorsabad), and Nineveh.8 The ruins of all four ancient cities fall within the modern state of Iraq.
References
Thank to everyone who has written in with comments and questions. Responses are posted here, along with a revised estimate from Dr Graham K. Taylor, and some alternate theories.
Chris & Tilde Stuart
Birds of Africa: From Seabirds to Seed-Eaters
MIT Press (1999)
G. L. Maclean
Roberts? Birds of Southern Africa
John Voelcker Bird Book Fund, Cape Town, South Africa (1985)
Graham Chapman, John Cleese, Eric Idle, Terry Gilliam, Terry Jones, Michael Palin
Monty Python and the Holy Grail
Python (Monty) Pictures Ltd. (1975)
SAFRING results of the European Swallow (Hirundo rustica)
Department of Statistical Sciences, University of Cape Town (2002)
Graham K. Taylor, Robert L. Nudds, Adrian L. R. Thomas
Flying and swimming animals cruise at a Strouhal number tuned for high power efficiency
Nature 425, 707?711 (October 16, 2003)
Email correspondence with Graham K. Taylor of the University of Oxford Zoology Department (October 22?23, 2003)
Kirsty J. Park, Mikael Ros?n, Anders Hedenstr?m
Flight kinematics of the barn swallow (Hirundo rustica) over a wide range of speeds in a wind tunnel
The Journal of Experimental Biology 204, 2741?2750 (2001)
Ashur Cherry
Assyrian History
The Mesopotamian Encyclopedia (2001)
