Cleaning Exhaust Tip?
Ok, so here's the deal, I just got my new quad set up, so the new tip on the right side of the car is brand new, and the one on the left is already run in, you know, smoke, and black and everything. So my car kinda looks silly, with one side new, one side kinda dark and old, is there any product I can use to clean my older one a bit to make it look a bit newer?
If the surface has significant tar or carbon contamination, or oxidized/swirled - i'll bring out one of those dual density, yellow and green foam cleaning pads and rub it with the heavier foam vigorously. (Don't get it wet, let it soak in product instead - it will be difficult at first but it will be much more effective this way) After a few applications it will be slightly hazed from the heavy sponge. To remedy this, flip it to the soft side and start polishing away with smaller amounts of the metal polish than before to give it a shine and take advantage of the polish, as apposed to the chemical cleaner removing heavy contamination. Also, this will prevent future contamination because this product creates a strong water repellent effect that lasts for months.
My Ride: Mach5 05' 530i Black Sapphire Metallic w/Auburn Leather Seats, Heated Front/Rear Seats, Cold Weather Pkg, Premium Pkg, Sports Pkg, Xenon Headlights, NAV, Mud Flaps, 20" 166 Style Rims
Model Year: 2005
Engine: N54
Try using what the motorcylist use on their chrome pipe. It's called Semichrome and can be picked up at any Harley Davidson Dealer! It's what the military and State Troopers use to shine their medals.
My Ride: BMW E60 530i , Silver with leather Air Con iDrive 17" Breyton Rims with Dunlop Sp Sport tyres (M-Tech Bodykit and rims WANTED)
Alfa Romeo 147 TS1.6 , Black with Air Con 17" Multi Spoke alloys with Bridgestone RE040 tyres
Toyota MR-S 1.8 VVTI , Lagoon Blue with Red leather Air Con 15" standard alloys with Toyo tyres
Toyota Celica 1.8 VVTI, Lagoon Blue, Air Con, 16" Standard alloys with Kuhmo KU31, EBC Green Stuff
Can you guys find wadding polish over there? It works great to shine up the tips and get rid of the black, caked-on stuff. Read this for more info:
http://www.autogeek.net/eo104.html
