Cleaning bird Sh*t
Old 03-11-2009 | 02:02 PM
Sam the BMW man's Avatar
My Ride: 2005 BMW 530i Oriental Blue Metalic Beige InteriorPremium PackageCold Weather Package
So I get out of work and I see all the birds in the northeast wanted to take a dump on my blue 5 series. I took it through the touchless carwash since its only around 40 today. Looks like the its still there not white but looks like its on the clear coat. Tried using some meguires detailer and some bug and tar remover and that didnt work. Does anyone have a home remedy to take care of this or know of a product?
Old 03-11-2009 | 02:12 PM
westcoast550's Avatar
Honestly you might be screwed, trying buffing it out with a scratch remover , but bird crap is toxic and it probably has gotten into your clearcoat.Samething happened to my black 540 e39 .......gl
Old 03-11-2009 | 02:16 PM
CWS530's Avatar
Bird poop is acidic and gritty since they eat little rocks to aid in digestion. Once you've carefully (i.e., not grinding it in while wiping) removed the poop, which you did in the car wash, apply isopropyl alcohol with some cotton to help draw out the acid. Let dry, then soap and rinse. Then claybar and wax.
Note: Claybar and wax the surrounding areas to blend, and try not to rub too hard on the spots themselves. Results depend on how much acid there was, but it's worth a shot. GL
Old 03-11-2009 | 02:18 PM
Krozi's Avatar
Originally Posted by CWS530' post='814043' date='Mar 11 2009, 06:16 PM
Bird poop is acidic and gritty since they eat rocks to aid in digestion. Once you've carefully (i.e., not grinding it in while wiping) removed the poop, which you did in the car wash, apply isopropyl alcohol with some cotton to help draw out the acid. Let dry, then soap and rinse. Then claybar and wax.
+1
Old 03-11-2009 | 02:39 PM
Originally Posted by Krozi' post='814046' date='Mar 11 2009, 06:18 PM
+1
Is isopropyl alcohol just rubbing alcohol?
Old 03-11-2009 | 02:43 PM
CWS530's Avatar
Yeah, just the kind from the drug store/Wal-Mart. The higher the % the better (usually 70-80). Check your bathroom cabinets.
Old 03-11-2009 | 03:20 PM
flyingpuck's Avatar
You will have to polish out the spot in your clearcoat! For your pain and suffering, a short video to lighten the mood!
Vman33
03-14-2022 04:43 AM
bestofthebest
03-28-2016 02:47 PM
bestofthebest
01-05-2016 07:47 PM
subieworx
09-21-2015 01:19 PM
ripley
DIY: Do It Yourself
09-19-2015 06:21 PM
Quick Reply: Cleaning bird Sh*t
