Car Cover Cleaning
...Was never really sure the appropriate way to clean a car cover (other than washing outside, turning inside out and washing inside)...I use mine daily and the inside eventually gets dusty/dirty. I have the BMW water-resistant cover...not the cloth one. Anything more specific I should or should not be doing?
I searched a bit on the net and basically found out that you need to follow the manufacturer's instructions because some covers can be washed in a washer and some can't. Most can't be dried in a dryer.
I spray mine with a hose while it's on the car and let it dry on the car. I pull up the sides a bit to circulate the air.
I guess if you want to wash the underside, just put the cover on in reverse and hose it down.
socale39
09-05-2023 08:30 AM
SFx550i
04-14-2015 05:00 PM
carid
03-06-2015 04:58 AM
