BREAK DUST!!!!
My Ride: 2005 E60 BMW 525i - BIRTHDAY- 11/04 - EXTERIOR- Amethyst Gray Metallic. INTERIOR- Beige Dakota Leather w/Dark Poplar Grain Wood. OPTIONS- Automatic Transmission, Premium Package, Cold Weather Package, 6-disc CD changer, Bluetooth using Verizon Raza V3c phone, SIRIUS Satellite Radio. ADD-ON's- 545i Chrome Grill, Euro Red Reflectors, Factory all-weater matts & Factory Coat-Hanger.
I am cleaning break dust off my rims EVERY DAY, is there anything I can do to help with this problem? I just thought at first it was because the car was sitting around before I got it and had a lot of rust build up from sitting at dealership, but now it's all gone but the break dust seems to be even worse!! HELP
Brake dust is a common problem among all continental cars. There is nothing you can do about it. Try polishing your rims. Might make it too smooth for the dust to stick. Alternatively you can try some aftermarket brands but I wouldn't advise it. Better to stick to originals especially where the safety parts are concerned.
Anyway, it is a good sign to have brake dust on your rims. It goes to show that your brakes are working fine.
Banned
There's no way to avoid it. To minimize it, and make cleaning easier, I've been using Rejex 3 or 4 times a year on my wheels. It doesn't break down from the high heat like wax will:
http://www.corrosionx.com/rejex.html
Between washings, I use a California mini duster on the wheels--takes 5 minutes and they're clean:
http://www.calcarcover.com/product.aspx?id=1021&cid=101
My Ride: 2005 545i
The reason why the car has so much brake dust is because they use a soft compount pad. As much as the dust sucks, its better than using a hard pad that will possibly warp out your rotors. Hard pads are very tough on rotors.
Best bet is to wax your wheels and use lots of elbow grease.
Banned
Originally Posted by JonsTintedTails' date='Jun 6 2005, 08:02 AM
The reason why the car has so much brake dust is because they use a soft compount pad.? As much as the dust sucks, its better than using a hard pad that will possibly warp out your rotors.? Hard pads are very tough on rotors.?
[snapback]136684[/snapback]
My Ride: 545i Sport Auto (see sig)
Yup, go over them with a mini-duster every day after work. Just make it a ritual after you get home. Dust the rest of the car with a regular size duster also once a day.
Banned
[snapback]136727[/snapback]
The other suggestion is to only dust when it looks like it needs it--the less you touch the painted surfaces, the less you risk damaging them. Unless I travel through a dusty area (like it's been the last few days here with the high winds), I usually dust the car twice a week or less, and the wheels once a week.
Originally Posted by stream' date='Jun 6 2005, 08:09 PM
[quote name='Merzbow' date='Jun 6 2005, 10:44 AM']Yup, go over them with a mini-duster every day after work. Just make it a ritual after you get home. Dust the rest of the car with a regular size duster also once a day.
[snapback]136740[/snapback]
[/quote]I've always been afraid to dust my car (especially because it is black). Can it really be done safely without scratching the paint?
Banned
Originally Posted by BMW#4' date='Jun 15 2005, 11:31 AM
[quote name='stream' date='Jun 6 2005, 08:09 PM'][quote name='Merzbow' date='Jun 6 2005, 10:44 AM']Yup, go over them with a mini-duster every day after work. Just make it a ritual after you get home. Dust the rest of the car with a regular size duster also once a day.
[snapback]139784[/snapback]
[/quote]I've been using the Calfornia car duster on several cars for quite a few years, with great results. I've never owned a black car, but I first heard of the duster years ago on a Porsche board, from this guy had a black turbo and was the most anal person I've seen regarding keeping his car in pristine condition. He highly recommended it, and even had 1,000 wt halogen lights in his garage for when he detailed his car. I used it for 4 years on an anthracite car and never saw any scratch marks from it.
I wouldn't recommend using it after driving in a rain storm when mud or lots of dirt got on the car, but when used to remove dust from the car, supporting the weight of the handle and only allowing the duster to lightly brush the car, you should be in good shape. I also shake out the duster 4 or 5 times while dusting the car. Also brush "as the wind would blow over the car" in straight strokes (never in circles) like you would when wiping down after a wash.
