Big "A" Detailing Queens, NY (718) 445-9995
05 Black BMW 330i clear coat correction
Flex rotary
3M Perfect-It 3000 Extra Cut Rubbing Compound
3M Perfect-It Ultrafine Machine Polish
Collinite 476S Super Double Coat Paste Wax
1 hood 50/50
![](http://i24.photobucket.com/albums/c17/triangle05/1-12.jpg)
2 hood 50/50 closer
![](http://i24.photobucket.com/albums/c17/triangle05/2-14.jpg)
3 hood driver side before
![](http://i24.photobucket.com/albums/c17/triangle05/3-14.jpg)
4 hood driver side after
![](http://i24.photobucket.com/albums/c17/triangle05/4-9.jpg)
5 passenger fender 50/50
![](http://i24.photobucket.com/albums/c17/triangle05/5-6.jpg)
6 passenger fender before
![](http://i24.photobucket.com/albums/c17/triangle05/6-6.jpg)
7 passenger fender after
![](http://i24.photobucket.com/albums/c17/triangle05/7-5.jpg)
8 passenger fender after
![](http://i24.photobucket.com/albums/c17/triangle05/8-3.jpg)
9 passenger fender 50/50 close
![](http://i24.photobucket.com/albums/c17/triangle05/9-2.jpg)
10 passenger fender 50/50 close
Flex rotary
1 hood 50/50
2 hood 50/50 closer
![](http://i24.photobucket.com/albums/c17/triangle05/10-1.jpg)
11 gas cap 50/50
![](http://i24.photobucket.com/albums/c17/triangle05/11-1.jpg)
12 passenger quarter panel before
![](http://i24.photobucket.com/albums/c17/triangle05/12-1.jpg)
13 passenger quarter panel before closer
![](http://i24.photobucket.com/albums/c17/triangle05/1-13.jpg)
14 passenger quarter panel after
![](http://i24.photobucket.com/albums/c17/triangle05/2-15.jpg)
15 passenger quarter panel after close
![](http://i24.photobucket.com/albums/c17/triangle05/3-15.jpg)
16 passenger dog leg
![](http://i24.photobucket.com/albums/c17/triangle05/4-10.jpg)
17 passenger quarter panel before
![](http://i24.photobucket.com/albums/c17/triangle05/5-7.jpg)
18 passenger quarter panel 50/50
![](http://i24.photobucket.com/albums/c17/triangle05/6-7.jpg)
19 passenger quarter panel after
![](http://i24.photobucket.com/albums/c17/triangle05/7-6.jpg)
20 passenger quarter panel after
![](http://i24.photobucket.com/albums/c17/triangle05/8-4.jpg)
21 driver door before
![](http://i24.photobucket.com/albums/c17/triangle05/9-3.jpg)
22 driver door before close
![](http://i24.photobucket.com/albums/c17/triangle05/10-2.jpg)
23 driver door handle before
![](http://i24.photobucket.com/albums/c17/triangle05/11-2.jpg)
24 driver door below molding before
![](http://i24.photobucket.com/albums/c17/triangle05/12-2.jpg)
25 Johnny rinsing the car off after compounding & polishing were done
![](http://i24.photobucket.com/albums/c17/triangle05/1-14.jpg)
26 water beading after compounding & polishing
![](http://i24.photobucket.com/albums/c17/triangle05/2-16.jpg)
27 driver door after
![](http://i24.photobucket.com/albums/c17/triangle05/3-16.jpg)
28 driver door after close
![](http://i24.photobucket.com/albums/c17/triangle05/4-11.jpg)
29 driver door handle after
![](http://i24.photobucket.com/albums/c17/triangle05/5-8.jpg)
30 driver door below molding after
![](http://i24.photobucket.com/albums/c17/triangle05/6-8.jpg)
after applying Collinite 476S Super Double Coat Paste Wax
31![](http://i24.photobucket.com/albums/c17/triangle05/7-7.jpg)
32![](http://i24.photobucket.com/albums/c17/triangle05/8-5.jpg)
33![](http://i24.photobucket.com/albums/c17/triangle05/9-4.jpg)
34![](http://i24.photobucket.com/albums/c17/triangle05/10-3.jpg)
35![](http://i24.photobucket.com/albums/c17/triangle05/11-3.jpg)
36![](http://i24.photobucket.com/albums/c17/triangle05/12-3.jpg)
driver side sun shots. yes, i finally got good sun shots after a correction job!
37![](http://i24.photobucket.com/albums/c17/triangle05/37sunshot1.jpg)
38![](http://i24.photobucket.com/albums/c17/triangle05/40sunshot4.jpg)
39![](http://i24.photobucket.com/albums/c17/triangle05/38sunshot2.jpg)
hood sun shot
40
31
32
33
34
35
36
37
38
39
hood sun shot
40
![](http://i24.photobucket.com/albums/c17/triangle05/39sunshot3.jpg)
wow , great!
u use only flex rotary or you finish with da? also i just got an flex DA and not sure what speed works better, is a powerfull tool , i think i saw a DA flex in one of your posts...
thank`s Cosmin
thank`s Cosmin
What a transformation! Well done!
thank you.
thanks again.
the only machine i used was the Flex L3403 VRG Rotary. they call it the "mini". its a great machine, has lots of power & it will keep your body a little more fresh from fatigue due to it being light weight. its about 3 lbs lighter than my Dewalt DW849 Rotary machine. the dewalt is still a little more heav duty than this Flex. the Dewalt is still my fav machine but its not needed all the time.
gracias mi amigo lol!
thanks again.
