Best way to remove swirl marks?
My Ride: 2003 Audi RS6/2002 Porsche 911 Turbo/2007 Toyota FJ Cruiser
Originally Posted by tex_phil' post='661204' date='Sep 3 2008, 07:09 PM
+1
Polishes:
Einszett Pro Line
Menzerna
3M
Here are some videos
Here are some good starter kits
Originally Posted by jmsod' post='661183' date='Sep 3 2008, 06:25 PM
Looking for the best way to get rid of the swirls. Thanks in advance to all you detailing gurus.
Originally Posted by C's Bimmer' post='661450' date='Sep 3 2008, 11:30 PM
The answer is simple, since you live in NJ. Take it to the guy that replied right above me. Phil is the FMINUS of the East!
Originally Posted by pyiu' post='661441' date='Sep 3 2008, 09:25 PM
I would have to say get a Flex XC3401 or at the bare min a PC.
Polishes:
Einszett Pro Line
Menzerna
3M
Polishes:
Einszett Pro Line
Menzerna
3M
+1 on this stuff right here
or take it to phil and watch from one of the best
My Ride: E53 E60 E92
Polishes:
Einszett Pro Line
Menzerna
3M
Polishes:
Einszett Pro Line
Menzerna
3M
Reason Flex is better:
1) more powerful and true DA (dual action polisher), you can press down hard of the pads and the agitation would not diminish since it uses gear mechanism. PC is random orbital, meaning if you press on the pad it agitates less and less, bog-down. You can correct (get rid of swirls) more on Flex by tayloring on the pressure of the pads.
2) Higher speed setting 5 on Flex is like 6 on PC, so the higher RPM (w/ less pressure) allows you to jewel the finish.
3) Trigger is variable, PC is on-off.
At the end, you can correct deeper scratches in less time. I remove deep scratch (taking out about 4-6 um of clear using MEG105 with Flex according to my Defelsko Combo PG meter and it finish LSP ready in 1 pass, that's about 2'x2' in 45 sec folks). It can be beast if you want to like in this case.
But gentle, light pressure, LC white and Menz PO85RD, paint meter register 0-um taken.
Love my Flex3401, I doubt I'll go to rotary anytime soon.
