Dealer Purchasing & Service Forum What's your dealers sales and service department like? Post finance and lease questions here too.
Technical Help re: Sirius
Old 04-10-2005, 06:04 PM
vulcan747
Guest
Posts: n/a
Send me a fax number and I can send the programming protocol steps to you.
Tommy
Old 04-11-2005, 07:13 PM
Rawn's Avatar
My Ride: Ordered Jan 11/05 545 Step, Black Saphire, Truffle Brown, Sport, Logic, Sat Prep Waiting.........................
Tommy
[snapback]113932[/snapback]
Thanks Tommy,
My FAX number is 514-481-1914.
Many thanks in advance.
Old 04-19-2005, 06:03 PM
Guest_Mike_*
Guest
Posts: n/a
....on the same note, I just picked up a 2004 645ci from a dealership in Toronto. I called BMW in New York as I was considering driving over to have Sirius installed (retrofit). They advised me that, after a VIN search, the car was not pre-wired for it and there is nothing they can do about it.
I have decided to install a Plug n Play Sirius radio. BMW has "warned" me that this may affect the iDrive system. I am quite sceptical, as it uses the FM Modulator (no direct hook-up to the stereo) and power from back side of the cigarette lighter. Does anyone know if in fact this will affect (i.e. crash!) my iDrive system? Thanks in advance!!
Old 04-19-2005, 06:57 PM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
If you're using the FM modulator, I don't see any reason why you'd have any issues with iDrive.
Obviously, you won't be able to change stations, etc. with the iDrive controller, only volume and tone could be adjusted. The FM modulator never sounds as good as a system that uses an aux input or the factory Sirius but it might have to do since your options are limited...
Old 04-20-2005, 04:15 AM
Guest_Mike_*
Guest
Posts: n/a
Thanks for the quick reply! Do you think if I use an aux input it would cause iDrive issues (call me paranoid!)? The place that's installing it doesn't think so, but then again, they are an auto sound system specialist, not a BMW specialist. Thanks again.
Obviously, you won't be able to change stations, etc. with the iDrive controller, only volume and tone could be adjusted.? The FM modulator never sounds as good as a system that uses an aux input or the factory Sirius but it might have to do since your options are limited...
[snapback]117391[/snapback]
Old 04-20-2005, 04:53 AM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
The only aux input that I'd use is the one that BMW installs. Once they've installed the aux input, you can connect anything (iPod, XM, Sirius, etc.) without any issues...
Old 04-20-2005, 04:48 PM
Guest_Mike_*
Guest
Posts: n/a
Originally Posted by Rudy' date='Apr 20 2005, 07:53 AM
The only aux input that I'd use is the one that BMW installs.? Once they've installed the aux input, you can connect anything (iPod, XM, Sirius, etc.) without any issues...
[snapback]117592[/snapback]
Thanks very much.
Kaane
03-15-2022 05:16 AM
ENDEE666
06-07-2016 10:31 PM
spykes
11-26-2015 09:58 PM
JayArras
Lounge
08-30-2015 02:08 PM
darnell moore
08-09-2015 07:50 PM
Quick Reply: Technical Help re: Sirius
