Dealer Purchasing & Service Forum What's your dealers sales and service department like? Post finance and lease questions here too.
service
Old 10-06-2005, 09:26 AM
Jeffs's Avatar
My Ride: 2003 X5 3.0----->gone 2004 Porsche Cayenne S : Gemballa front and back bodykit, fabspeed bypass pipes, Gemballa exhaust pipes, full option, 20" factory sport design rims------>gone 2005 545i 6-spd manual---->de-badged, CDV removal, Autosolutions short shift kit, resonator removal, premium package, PDC, xenon, almost full options, hardwire V1 install ....looking for mods... 2007 550i 6-spd----> Premium package, sport package, Logic7, heated everything, Rogue Engineering SSK, CDV removal, hardwire V1 install, aFe cold air intake, Custom Magnaflow exhaust....
I have 16,000 miles on my 545....but there is no service light going on....is anything wrong?? My previous bmw (X5) needs servicing after 15,000 miles....and I have never changed my oil either....sounds strange....In my cayenne I changed oil every 10,000 miles....is anything wrong?
Old 10-06-2005, 09:32 AM
AC_S5's Avatar
when you start your car, there's a count down of miles on the display, what does it say?
Did you also check your iDrive to see if you are due for a service?
Old 10-06-2005, 11:00 AM
Jeffs's Avatar
i do not see any countdown....and I-drive says service OK....i dton know whats going on
Old 10-06-2005, 11:11 AM
vffun's Avatar
My Ride: 2006 525i Jet Black (Base + PDC)
I don't know whether we have this on our E60...in the MB system, the car will monitor the oil quality and only advise to change when required. If you drive mostly highway, then you can go longer without oil change....
Old 10-06-2005, 07:34 PM
mikej's Avatar
I think it appears right when you start your car then it goes away.
Old 10-06-2005, 08:44 PM
AC_S5's Avatar
[snapback]180669[/snapback]
Yup on the bottom screen, you can also check it in the iDrive and it does vary with different driving condition as suggested. If your iDrive say ok then is fine. But you can always ask your dealer and they might change your oil before is due sometimes.
Old 10-06-2005, 08:46 PM
EBMCS03's Avatar
There is a countdown timer... look for it. BUT there have been cases where the countdown timer doesnt work and gets stuck at a certain milage... so I would look into it if I were you. I'll see if I can pull up the thread to that.
Old 10-06-2005, 08:49 PM
AC_S5's Avatar
[snapback]180703[/snapback]
That would suck :thumbsdown:
Old 10-06-2005, 08:54 PM
EBMCS03's Avatar
FOUND IT!
http://forums.e60.net/index.php?showtopic=...l=service+count
P.S. MAN I dont like the minimum of 4 character search... I know I can use the * to fill in characters... but boy it still took some effort...
Old 10-07-2005, 05:47 AM
Ricracing's Avatar
[snapback]180486[/snapback]
The iDrive should tell you the miles you have left before maintance, brakefluids, brakepads, cooling liquid etc.
Anyway, it doesn't harm your car if you take it in for a sercive right now!
With 16,000 miles you car should be do anyway.
Quick Reply: service
