5Series.net - Forums
-   Dealer Purchasing & Service Forum (https://5series.net/forums/dealer-purchasing-service-forum-23/)
-   -   BMW North America Is A Ripoff (https://5series.net/forums/dealer-purchasing-service-forum-23/bmw-north-america-ripoff-82563/)
blackfalcon Jul 31, 2009 06:09 PM
Just a quick note. I had another post about 6 weeks agao complaining that the SMG on my car was leaving me stuck in N at startup sometimes. I took the car into the dealership and and BMW NA claimed I needed a new $8000 transmission. It was very interesting, because the tech at the dealership implied that BMW DIS system does not let the technician see all the data from the car. They send all the data to BMW NA who makes the final decision as to what the issue is, and they don't always share the reason behind this with the local technician. I completetly disagreed with BMW NA and requested they have there regional rep come look at the car. He did and again stated it needed a new transmission.
I picked up the car to go get a second opinion from someone with a GT1. The car did act up at all after I picked it up for another 1000 miles or so. Wednesday the car completely starting shutting down, and eventually bricked itself in my driveway and would not shift into any gears.
I pushed the car into my garage and put it up a lifts, and got out my volt meter and started checking what voltage etc. was being sent to the pump, etc. from the main smg controll unit. I ended up figuring out that it was just a bad SMG Hydrolic pump motor. It wasn't completely shot, it would hang up sometimes when it was asked to start, and would start with light tap from my finger.
The motor was ridiculously easy to remove. There are only two/four bolts holdilng it to the hydrolic pump (only remove the torx bolts not the hex) and three mounting it to the transmission. BMW doesn't sell this little tiny motory by itself here in the states. You can only buy the whole damn hydrolic assembly to the tune of $3800. The is a completely absurd thing for BMW NA to do.
I took the motor into a shop that rebuilds them and he put it on some sort of tester and reved it up for a while and then handed it back to me and claimed it was fixed. (something about the grease in the bearings needed to be heated up and spun into place?) I took it back home and put it back in car and everything has been running fine since. FYI, you don't have to take the car in to blead tranmission, or have a DIS/GT1 at home.
The moral of this story is this... Don't believe BMW NA when they are trying to part you from your $$$. Take it for a second opinion first.
Secondly, if anyone nows were I can buy a DENSO hdryolic pump, I'd sleep better at night, instead of worrying that this one will crap out on my again.
http://getchelldevelopment.com/image...pump%20011.jpg
DrLev99 Jul 31, 2009 06:25 PM
So you were lucky enough to find a shop that just happens to rebuild SMG Hydrolic pump motors?
Lucky you....saved some serious bucks. :cool:
jprovence Jul 31, 2009 09:14 PM
SMG or not, a hydro pump is a hydro pump. The shop doesn't care it runs an SMG tranny. We need to get one of these apart, figure out who manufacturs the o-rinds and seals and whatever else is in there if we want to keep driving these cars into the future. Or we won't see in of these cars like we see old e30s and e28's on the road.
boukehj Jul 31, 2009 10:52 PM
You could drop them a line...
http://www.denso-europe.com/DENSO-Manufact...0000000001.aspx
blackfalcon Aug 1, 2009 03:58 AM
Originally Posted by boukehj' post='961754' date='Aug 1 2009, 02:52 AM
The tech at BMW told me that I could try Denso, but they probably have an agreement with BMW and will not sell you only the motor. What is more promising though is the other thread about SMG's led me to this... I'm not sure thought if hydraulic pump is referring to the pump or the electric motor. This makes me think though, that the electric motors from the E46's could probably be made to work.
Part 23427571297 (Repair kit, hydraulic pump) was found on the following vehicles:
E46: Details on E46
E46 325Ci Convertible
E46 325Ci Coupe
E46 325i Sedan
E46 325i Touring
E46 330Ci Convertible
E46 330Ci Coupe
E46 330i Sedan
E60: Details on E60
E60 525i Sedan
E60 530i Sedan
E60 545i Sedan
E60 550i Sedan
E63: Details on E63
E63 645Ci Coupe
E63 650i Coupe
E64: Details on E64
E64 645Ci Convertible
E64 650i Convertible
E85: Details on E85
E85 Z4 2.5i Roadster
E85 Z4 3.0i Roadster
wolf Aug 1, 2009 04:42 AM
WOW! Glad you were able to catch this yourself!
v_therussian Aug 1, 2009 07:02 AM
Blackfalcon, you are henceforth my hero! :notworthy: :clap:
javelin73 Aug 1, 2009 08:04 AM
+1 :P ,
here in Germany you also have to look for another opinion - or just call www.e60forums.com, here are the real
BMW specialists! :rolleyes: :D :P
studavis Aug 1, 2009 08:16 AM
You guys kill me with all the knowledge you have about these cars. I have spent 2 weeks avoiding the task of replacing a fuse.
Impressive work man.
v_therussian Aug 1, 2009 08:30 AM
we don't know how to change a fuse either - we let BMW of NA handle simple lil' things like that :lol: :P
