Another BMW service blunder
So like I posted in the loose tire valve thread-I had a problem with what I now know as the TMP valve on the tire. Which someone had posted works by using abs sensors to measure wheel speed and senses if one is turning slower-well that cannot be true as each wheel has its own sensor.
Anyway I had ONLY the back 2 tires replaced at a bmw dealer-the one that to me is just a disaster here in phoenix. Well the guy at discount tire tightened these bolts on the tire pressure sensors and the right back on that was letting air out and set off my sensor was barely hanging on and then he checked the left back one and it was also really loose. The fronts were fine. Now it is too much a coincidence that I had 2 back tires changed and 2 sensors loose-and 2 untouched tires and 2 complete fine bolts.
Again unacceptable for paying the extra cash and taking the extra time to do things at a dealer it just doesnt pay. Anyway sensor tightened and all fine and well
My Ride: E90 M3
Model Year: 2011
Either way, is there no other BWM dealer in Phoenix you can use, this one sounds awful!
TroyE60
05-30-2019 05:01 PM
S4CH
05-04-2015 09:37 AM
