$950 to pre wire and install IPOD in an 07!? WTF...
My Ride: 2006 bmw 530xi
Thanks for all of the feedback. I called the same dealer again this morning and the parts guy is now quoting $350 for the part (invoice from this weekend shows $370) so more bs... I will check around with other local dealers and see if any of them will be at a reasonable price.
At this rate with the 1 cd at a time I might as well get in the car, gun it to 88 and take it back like an 8-track...
Thanks everyone
Thanks everyone
My Ride: 2007 530i ~ Fully loaded | Sport Package
20" VIP Modular Wheels
ICE by Method Sound
M Style Body Kit
Stop Tech BBK
FK High Sport Coilovers
RPI Exhaust
RPI Air Intake
Posted Today, 03:40 PM
Thanks everyone
go to bavarian auto they have it for about $315-320 no tax and it is the original ipod interface that bmw dealer sells!check it out but you still have to find someone who will program the car.look around it does not have to be a dealer because you might get lucky and find an independent bmw mechanic with the right hardware to do the job.i am very happy with it and you will be too!TRUST ME ON THAT KID!ITS WORTH IT!BUT NOT WITH THE STEALERSHIP PRICES1
Thanks ofr the heads up, I will check them out, Im in southern CA so going to NYC wont happen
I am talking wiht a couple bmw mechancs on it now.
Thanks everyone
My Ride: 04 545i sport, stick, L7, sat, nav. Charcoal/ runflat/ cdv delete.
Suede headliner/ trunk, 3 way front speakers, four 8" subs in rear shelf, ACM, iPod dock in ash tray using gateway 500 with MP3 text and video on screen, MRTM aluminum pedals/ door pins, 10 farad cap, sound processor, line conditioner, 2 amps ( 4x100 and 2x200)
(5e60er - give me a call, I offer a reasonable price for the gateway or oem adaptor installation, which includes installation and programming) your PMs are blocked?
OK guys, I will go ahead and play devils advocate here, take it easy on me as this looks like an uphill battle at this point. It is fine if you disagree with me here, but please do not flame me on this one, as I am not trying to go to battle over the cost of the iPod. I am just trying to provide a shop perspective for everyone. So here it goes:
First of all, the factory iPod adaptor ( Alpine adaptor, not the SA-6FL usb option ) is about $200 less then the Gateway unit. Do not confuse one for the other. The retail price of the Gateway is $599, and lets just say that here in the US, the cost is higher then what I see posted. As a shop owner, I understand the iPod adaptor, with installation, gets a bit expensive on these cars, but the quality of the audio and the interface control is excellent. For those of you that are willing to find the unit somewhere on ebay, install it yourself, and then get a good deal at the dealer for programming-I say good for you. You saved some money doing it yourself ( so long as your not paying the dealer $600 for programming ). But for everyone else, I would say it is not reasonable to expect a shop to sell the unit, install it, and program it for $400.
As for programming time, not all cars take the same amount of time to program. Cars older then 03/05 need the MP3 retrofit programming in addition to the iPod programming. If your software is fully up to date, the iPod programming is under an hour. However, some cars really do need 8 hours of programming because the whole system software is out of date and will be unstable if you add the iPod without updating the system first.
Model Year: 2010
I agree with methodsound.
iPod retrofit software activation requires MP3 activation, which may require CIPS/PROGMAN update, which may require update of certain control modules. My BMW Center described the same process when I had my BMW / Alpine BMW interface installed.
Most BMW Centers will quote on the high end, in case they are stuck with an 8-hour job updating various pieces of software on the car, which they have to babysit.
ICE by Method Sound
M Style Body Kit
Stop Tech BBK
RPI Exhaust
RPI Air Intake
I will give you a call tomorrow, thanks for all the feedback
where in nyc did you go to get it done? im in NY need someone to program.
thanks man
My Ride: E60
Engine: N54
I JUST installed the Dension Gateway 500 in my non-CDC player and it was EASY. Tap HOT, GROUND, and FIBRE (where you see the light of the fiber is IN to the GW I believe?)... plug into the CAR side of the GW500. So easy a caveman can do it! (Although I must admit I fumbled and fumbled looking at the directions, you just have to quickly build the connectors and everything is provided in the kit.)
http://dension.com/download.php?file...tallguide1.pdf
I used Instation Type 3b per the above instructions.
PM FANTASTIC 5 for a deal on the GW500. (Everything I've read says the GW is faster and better than the factory iPod connection kit.)
All that said... Can anyone in the DC Metro area do my programming?
