Fs: 2010 e61
My Ride: E61 535 & an E30
https://www.facebook.com/marketplace...79132496254124
Time to let this one go. I have taken care of it like I thought I would keep it forever. While not perfect, it had a rough life with previous owners as far a swirl marks/scratches, I am asking $10K based on the maintenance put into it over the years.
Oil changes every 6K since I have owned it since mid 2015.
Major Services/repairs
Transmission Service at 51k 9/15
Rear hatch wiring replaced 4/16
Valve Cleaning at 63k 6/16
Boost Control valves replaced at 65k 7/16
Valve cover Gasket at 71K 12/16
Vanos solenoids replaced 77K 6/17
Ignition Coils, Spark plugs and front brakes at 80K 9/17
Fuel Pump replaced 81K 10/17
Heater Control Valve replaced 89K 4/18
Rear brakes and Drive belt replaced 92 8/18
Oil pan gasket, front axles, oil cooler, engine mounts, control arms replaced 93K 8/18
Front brakes replaced 105K 9/19
Front strut mounts replaced 107K 12/19
Oil Thermostat, brake flush 110K 7/20
Current issues Left DRL not working. I have an extra set of LCI adaptive headlights for parts.
It has a small oil leak could be the oil pan gasket or rear main seal.
It's not leaving anything on the ground over night but it is leaking.
It is a California Manufacturer buyback. Supposedly from the high pressure fuel pump issues at the time.
That being said, so far this car has only had normal issues do to age and has been a very reliable car.
