Selling my 2008 535xi - owned it for about a year. This N54 powered wagon has had EVERY N54 problem addressed within the last 20k, see the capitalized text covering said issues. This car has extensive work done to it - I bought it thinking I would be keeping it forever and eventually manual swapping it, but, plans change. No rust - normal wear and tear, no major dings (seriously really straight, there is marks from a door, but, no dent, just a scuff)
POSTING ON CARS AND BIDS
Options:
Comfort Access
Logic7
Automatic tailgate
Adaptive bi-xenons (retrofitted)
Rear Sunshades
Heated front and rear seats
Heated Steering Wheel
Comfort seats (these are like, 21 way adjustable)
Rear cargo cover + dog net
SHADOWLINE TRIM!!
USB port + Aux input
Parking sensors front and rear
Mods:
MHD Stage2+ (18psi)
xHP Stage1 transmission tune
xDelete custom percentage (20% max power goes to the front)
Rev9 intercooler (Wagner replica, works great, can show data logs)
VRSF catless downpipes
Retrofitted headlights (look at the last photo for output on lowbeams)
Hardwired for dashcam
Hardwired for Escort Radar Detector
Gloss black grilles
New Phillips Xtreme vision d1s bulbs
35w 3000k fogs + fog tint
Maintenance:
Last 20k:
HIGH PRESSURE FUEL PUMP
INDEX 12 INJECTORS
Low pressure fuel sensor
Walnut blasting
Valve Cover gasket
Spark plugs
ELDOR COIL PACKS
Pads and rotors front and rear (Centric rotors, Akebono ceramic pads)
Transmission Sleeve
Transmission seals under the Mechatronics
Transmission solenoids
Transmission pan with filter
Filled with OEM ZF fluid
Last 5k:
Rear tires
Transmission fluid (again with ZF fluid)
Transfer case mount
Transfer case fluid (OEM Shell)
Front diff fluid (Redline)
Rear diff fluid (Redline)
Both motor mounts
WATER PUMP
THERMOSTAT
OIL FILTER HOUSING GASKET
OIL COOLER FEED LINE ORINGS
I am sure I am forgetting more. Oil was changed every 3k since I have owned it with OEM Mahle filter and Shell Rotella T6. 5w-40.
Runs and drives great.
PM me any questions.
Reason: Posting on Cars and Bids
