2007 e61 6MT 530xit
Old Jun 12, 2022 | 03:43 AM
NeedAnE61's Avatar
My Ride: 2007 SG/Black E61 | 6MT
Model Year: None
Default 2007 e61 6MT 530xit
2007 BMW 530xiT - Hunt Valley, MD.
  • Silver Gray Metallic
  • Black Interior
  • 6 Speed Manual
  • 230,000 Miles
  • Clean title
Below is a list of things addressed during my ownership, broken out by category:
Engine
  • Starter
  • CAS Module
  • CAS Module Wiring
  • Intake Manifold Gaskets
  • Throttle Body Gasket
  • Water pump
  • Thermostat
  • Radiator Hoses
  • Coolant Pipe
  • Temperature Sensor
  • Oil Pan Gasket
  • Valve Cover Gasket
  • Oil Filter Housing Gasket
  • Oil Cooler Gasket
  • Spark Plugs
  • Ignition Coils
  • Intake Disa Valve
  • EGR Heater / Angle Connector
  • PCV Valve
  • PCV Hoses
  • PCV Separator
  • Serpentine Belt
  • Belt Tensioner
  • Deflection Idler Pulley
  • Power Steering Tank
  • Clutch Delay Valve Delete
Suspension & Brakes
  • Tension Strut Bushings
  • Front Springs
  • Front Control Arms
  • Front Rotors
  • Front Pads
  • Rear Rotors
  • Rear Pads
  • Front Axle
  • Front Struts
  • Front Strut Mounts
Drivetrain
  • Shifter Rebuild and Upgrade (bushings, pins, carriers)
  • 18" wheels
  • Tires
Fluids
  • Coolant
  • Front Differential Fluid
  • Rear Differential Fluid
  • Transfer Case Fluid
  • Power steering fluid
  • Clutch Fluid
  • Transmission Fluid
  • Rear Hatch Motor Fluid
  • Brake Fluid
  • Regular Oil Changes
  • Regular Tire Rotations
Electrical
  • Idrive CCC Full System Rebuild
  • Battery
  • Hatch Wiring Completely Redone
  • Angel Eye Bulbs
  • Headlight Bulbs
Miscellaneous
  • Driver Seat Thigh Bolster Gear
  • Passenger Seat Thigh Bolster Gear
  • Headlight Washer Pump + Grommet
  • Front Windshield Washer Pump + Grommet
  • Rear Windshield Washer Pump + Grommet
  • Wiper Blades
  • Sunroof Clean + Remove Drain Check Valve
Known Issues
  • Night Vision Malfunction Warning on idrive
  • Rock chips on front bumper and hood
    I have done a lot of work to this car and it is really good condition. I am looking to get $10,000 or best offer.
andreiATL
Oct 3, 2019 07:42 PM
Kaane
Jun 2, 2019 05:50 PM
erock
Mar 29, 2016 06:12 AM
VarrsToen
Jun 26, 2013 04:51 PM
ModBargains
Archived Sales
Sep 9, 2010 11:36 AM
