Beck LM 800
My Ride: F02 LCI Individual
Model Year: 2013
Technical details / dimensions
Year of construction 2006
Country Switzerland
Price from 750 000 CHF
Displacement 4,2 l
KW/HP 478 / 650 / variable (up to 1200 HP)
Torque 900 Nm at 5,000 rpm
Weight 900 kg width full tank and incl. driver ( 80 kg )
Top speed over 350 kph
0 to 100 kph (60 mph) 3.0 sec
0 to 200 kph (120 mph) 7.0 sec
Length 3,960 mm
Width 2,043 mm
Height 951 mm
Fuel consumption ? 16 l
Engine model Beck LM V8 powered by MTM
Gearbox Semi-sequential, 7-speed
Tank capacity 120 l
The vehicle is available with different engines, from 550 HP up. Needless to say, with different engines, the performance figures will change.
The vehicle?s unladen weight and drag coefficient may be increased when special equipment is added to the vehicle, whereby the effective load and maximum speed are reduced accordingly.
All technical specifications and dimensions are to be regarded as guide values. Subject to change without notice.
Pics
Country Switzerland
Displacement 4,2 l
Length 3,960 mm
Width 2,043 mm
Height 951 mm
Tank capacity 120 l
Pics
Lotus99
11-26-2015 11:07 AM
turbo_mustang12
08-03-2015 09:53 PM
