will this tcu give me bluetooth
i have a late 2003 e60 with the usual steering wheel controls for phone and the menu in the idrive communication whan i select that it says bmw contact - then no numbers stored please contact bmw .... what does this mean? does it mean it had a tcu with a simcard in it that called bmw when the car was new and assist was active but does not have bluetooth but means i have a microphone etc alread and just need a tcu and the bluetooth antena?
will this tcu
Removed from an E60 54reg
Part number 84.21 6-953044-01
Manufactured Sep.2004
do the trick + antena + programming
will this tcu
The bmw contact list just stores the phone number of the dealer, they can add it them selves, In your head-liner is there a separate piece with what looks like a microphone grill?, If not then no microphone is fitted.
Check the left side of the boot behind the trim, the TCU is anchored to the suspension bulkhead, have a look and see if one is already fitted, also I have checked that TCU part no. in the ETK and can not get it to list the item, is the number correct?
My Ride: 05 545/6
will this tcu
will this tcu
if "54reg" means a 2005 model year car, then yes, that module should do it...but it is dangerously close to the cutoff (10/2004 was the first safe month, 3/04-9/04 required the programming.)
personally, I'd look for a newer TCU, but if that one is a steal than give it a try.
This is good info guys - are you saying a newer one will not need programing?
I have Yet to dig out my tcu
I have vents next to interior light is Mic in there? I have a sunroof button there 2 does this change Mic location?
My Ride: 05 545/6
no, your idrive unit (M-ASK or CCC) will need programming regardless. what i'm saying is TCUs from 3/04-9/04 ALSO need programming. the dealer's programming unit should recognize the need and update the programming if needed.
there are two microphone slots up in the roof, on LHD cars the left is for the TCU and the right is for the voice recognition. I'm not sure if the RHD cars swap the mic locations. that panel just pops off from the front, pull it down and see what you have there. insert a panel prying tool between the light and the panel.
Unless your TCU number is one of the numbers listed below you will be able to activate Bluetooth as long as your car is Pre-Wired for telephone(for U.S cars atleast). You will need programming no matter what
My TCU was one of the numbers listed below, I purchased a new TCU off ebay for $135 Shipped
84 11 6 937 338
? 84 11 6 938 782
? 84 11 6 942 592
84 11 6 937 338
? 84 11 6 938 782
? 84 11 6 942 592
Naa i haven't took it in yet, Was going to take it in a week or so and get the Ipod interface installed
Figured I'd get the programming done for both the TCU and iPod at the same time.
I tried messing with iDrive after installing the new TCU w/ no luck.
