ULF Upgrade
Folks,
I have one of the early ULF units in my 04 545i and of course I have to pair my iphone each time I get into the car to get it to work properly.
Can the software on this unit be upgraded to allow my iphone to work or would I be better off purchasing a 13th Gen ULF unit and swapping out ?
In addition to this I am guessing that the progman update is a completely separate upgrade from this ? I need to replace the cd player in the central console as its duff and I am concerned if I fit a newer more advanced version their might be some issues and I will need to update progman as well.
My eventual goal is to get a mobridge / ipod hooked up to idrive...
I really need some guidance on this from the experts on here, thanks in advance !
Best regards, Peter.
Originally Posted by bauderline' post='610412' date='Jun 26 2008, 01:40 PM
Folks,
P.
My Ride: UK 2005 535d Sport & Audi Q7 S-Line
Vis Pack, Media Pack, Heated fronts and Rears, HUD, Servo Steering,
I think your mixing up older bluetooth systems with newer ones.
The E60 bluetooth is fully upgradable via software ( progman ) and your going to need an upgrade to make your iPhone work correctly.
The 13th Gen ULF your talking about is the bluetooth system used in E39s ( and many others ) which were not software upgradable.
Get your software updated and you should be fine.
Si
Si
Si
Si
I am leaving the car in to have ipod integration fitted and they said the phone software would be updated as part of the "coding", so lets hope they do the needful !
It will be interesting to see how well the ipod integration works with the idrive given that i have an 03 car and likely older radio, although it is the pro version.
Thanks again !
P.
umnitza
09-02-2015 11:28 AM
Florida2002m3
09-01-2015 10:59 AM
