For those with an iphone snap-in
I had an idea that if the antenna connector isn't physical maybe the snap-in could be used with other similar sized smartphones to use the external aerial. Does anyone know for sure how the iphone snap-in exactly hooks to the iphone?
There have been various snap-ins made over the years that don't physically connect to the phone - the first one I remember was the Moto V3. It uses a principle of inductance and yes you could use that for any phones.
I have the ability to use both on my HTC. I made a custom lead from the cradle socket to the phone socket and also connected this to an inductance plate too. But I'm not able to make a neat looking automatic locking phone socket connection like you find in the OEM cradles so have to manually connect the plug in. Most of the time I don't bother to be honest because the inductance plate that I have works fine.
Thanks again.
I actually used an older cradle to get the lead that is used to connect the OEM socket to a thin coaxial cable. Just solder the coaxial cable lead to a small metal plate and that becomes your induction plate - just don't short the coxial cable. Connec the coaxial cable also to your phone socket plug and so then you have both done.
If you want the neatest solution get hold of a V3 cradle - they are old enough now to be available cheap. Then rip it apart and just use the cable with the induction plate from it.
My Ride: 2007 Mercedes CLS63 AMG
Designo Graphite with white leather interior
Keyless Go, Heated/Ventilated seats, Parktronic
Originally Posted by knowlk2' post='592053' date='May 30 2008, 11:47 PM
Got an iphone snap in on order since the iphone is almost exactly the same size as this phone.
Hope it works out! If not I'll break out the soldering iron.
i can see the Gen2 iphone having a different setup though. Kinda like how several ipod accessories don't work with the iphone.
speedlimit
5 Series Announcements
01-15-2018 12:34 PM
bestofthebest
01-05-2016 07:47 PM
