Swapped Cingular Motorola v551 for v557
I had noticed on Cingular web site that the specs for standby time on the Motorola v557 were much better than the v551. The life I was getting in standby was very poor, even with new battery. Rarely more than 24 and 36 hours at best. V557 claims of up to 16 days Now I realize that was optimum and that with Bluetooth enabled it would be considerably less, but 1/2, 1/4 ? So I changed out over the weekend. A few little features like an indicator in display when linked to Bluetooth device u can c in the window when clamshell is closed (as well as open too). Made my initial charge Saturday afternoon and so far it is still at full charge after 96 hours. Yee haw. I could almost go without cradle now. Still in test mode, but all else is the same as v551, that is to say very good performance and compatibility with 6er. Paired right up with no problems and transferred phone book as it should. The two phones are identical in physical appearance and form, fit, and function is identical. Other new feature is a little scrolling window with internet news when clam shell is open. This part is free but can subscribe to additional fee based systems. I won't, and may even kill the feature if I find it interferes with normal use.
Originally Posted by drjochen' post='222943' date='Jan 11 2006, 05:21 PM
Is this with BT on? I have a 551 and battery life with BT on is pathetic (1-11/2 days max). Does it fit in the 551 cradle?
My Ride: 2006 530i Sport
Silver Gray - Black Leather - Anthracite Maple
Manual Transmission
Premium Audio
Cold Weather Package
Rear sunshade
Sirius Radio
Autobahnd Roadblock (3M) film kit
[/quote]
This is kind of related to what I recently observed. I have an old V600 (it will be 2yrs old in April). I went on my first trip in the car, about 4.5 to 5 hours. From the stories here, I had been expecting the phone to die before the end of the trip. It not only lasted through the entire trip, it went the rest of the day with no problem.
I have the following settings under "Car Settings" in the V600:
Auto Answer: Off
Auto Handsfree: On
Power-off Delay: Continuous (I think this one matters)
Charger Time: Off (this one can be set for a set # of hours so it doesn't keep sucking the car dry)
I think the Power-off Delay is something that could have a large impact on battery life.
Auto Answer: Off
Auto Handsfree: On
[/quote]
It does not make a difference in my car as when the car goes to sleep, there is no more power supplied to cradle. It does not wake up for the phone at all. There are three things that can be set on the v551 that impact battery life but as I said, some do not impact its use within my 6er. I assume the power off to the phone is the same in the E60 cradle.
Power-Off Delay
(car kit)
Set the phone to stay on for a specified time after the ignition is switched off:
M > Settings > Car Settings > Poweroff Delay
Charger Time
(car kit)
Charge the phone for a specified time after the ignition is switched off:
M > Settings > Car Settings > Charger Time
Conserving Battery Power
Some networks and phones include a battery save setting
to extend battery life. When this feature is activated, your phone automatically turns off the keypad backlight when it detects that enough ambient light is available.
M > Settings > Initial Setup
The same settings are available in the v557.
Well I finally ran out of patience today and plugged the phone into the charger after nearly 7 full days of standby where my v551 never lasted more than two days. This is definately a keeper
umichchris
09-10-2015 12:54 PM
