SOLVED! My Nokia E71 bluetooth problem
Through a process of trial and error, I discovered that the problem I had with my Nokia E71 bluetooth connection continously dropping and re-establishing itself with my E60, was the fact that my phone contacts list was about 4,000 names.
Out of desperation I wiped my phone and tried the pairing process and lo ad behold - everyting's fine now.
Could anyone out there advise:
1. what is the limit of contacts that a phone can have before the car goes mad?
2. is there a workaround?
Thanks!
Thanks!
My Ride: G30 M550i
Model Year: 2018
There's clearly a memory limitation on the car that prevents an unlimited number of contacts to be received from the phone. I don't think anyone knows any concrete numbers (or memory size) but on my Blackberry, even though I have about 1800 contacts, I don't have issues with pairing, I just don't get a complete phone book transfer.
Nokia phones seem to be the most problematic when it comes to successful pairing with the E60... :thumbsdown:
My Ride: [b]1993 Toyota Supra MKIV (6-speed Targa top) - SP67DBB Single Turbo[/b]
Thanks!
Thanks!
When I had the problem of not getting the whole addressbook in iDrive I counted the entries and the maximum was only around 300 numbers (not contacts). If your addressbook is larger than that you will certain names and it is random. That's why I keep my phone in a phoneholder on the dash and use the phone to dial numbers.
My Ride: G30 M550i
Model Year: 2018
Originally Posted by Rudy' post='697022' date='Oct 19 2008, 08:02 PM
Again, it's hard to put an number on the exact total but my car clearly accepts more than 300 numbers from my BlackBerry. I have about 1800 contacts (many of them with multiple numbers) and if I attempt to transfer them all, it goes through the alphabet and stops somewhere in the middle of the letter 'T'. I never counted them but I'm positive that there's much more than 300 in there...
I think if you look closely there will a lot of contacts missing at every letter, the contacts are not transferred sequentially from A to Z bit random.
I'll count the pages of contacts in the iDrive screen again when I have time!
Well it's kind of different with each phone. With my e60 and e71, I have connected and used a bunch of phones with 300+ contacts without any error. They include Sony Ericsson and Nokia Symbian to HTC and O2 Window Mobiles. However, I have the connect and drop problem with 2 phone which are LG KS20 Window Mobile and Nokia N96 Symbian. Strange!!!! I really want to resovled the problem without changing phone because I like my new N96 so much that I don't want to change as of now.
Thanks!
Thanks!
I'm having the same BT drop problems with my brandnew E61 (veah!!) and my Nokia E71 - and I just hate it! I also tried to cut down my contacts from almost 2,000 to now 1,300 - still the same Could you pls tell me what firmware your Nokia has (just dial *#0000# - mine is 100.07.76) and how many contacts you have in you Nokia E71 now (with BT still working)?
Thanks!
Thanks!
My Ride: E90 M3
Model Year: 2011
I have a 1st Gen iPhone with over 1,400 contacts and they all load. Now a fair number are just e-mail addresses and those don't seem to appear, just the phone numbers. But that still comes to more than 1,000 entries and as far as I can tell they all load but I can't say I've checked every single one. When I first got the iPhone, I did have issues loading only part of the contact list, but I had more the 2,000 entries. Like Rudy I only got part of the alphabet or had glaring gaps in most of the letters. After cleaning out many old and duplicate entries, I got it down to just over 1,400 and it seems to do fine...
Thanks!
Thanks!
There is a new firmware for the E71
110.07.127
09-10-2008
Anyone tried it? according to this:
http://www.e71fanatics.com/2008/11/new-e71...-available.html
It's suppose to have some bluetooth improvements.
110.07.127
09-10-2008
110.07.127
09-10-2008
