Separating Aux from Bluetooth/MULF
I have had the same problems that many have had with loss of aux/usb/bluetooth w/ sos. I checked out my MULF and it looks to be quite destroyed along with the connections/wires that lead to it under the spare. If I thought connectors would still work I would be replacing the MULF right away, but I am concerned that they will not and I have never rewired connectors before and its something I would like to avoid if possible. The reason this all came up is because I simply am looking for a way to play music in the car other then the radio cd, so MY QUESTION IS: is there a way to bypass the MULF and lose bluetooth, but still be able to retain the use of the AUX jack? Thank you so much!
Also I have the non Hi-Fi system in my 2008 535i, is there a way to connect an aux cable going directly to the headunit?
beauplanjeff
Bluetooth & Cell Phone Forum
Feb 12, 2013 02:13 PM
