Phonebook synch question
I'm having a little trouble with the phonebook synch between my new 2010 550i and my Blackberry 8310. My car seems to download my BB's phone list every time pairing occurs, and it sometimes takes quite a long time for my phone list to transfer to my car. My BB has a security code on it, and if I forget to enter the security code before going into the car, the phonebook doesn't synch at all, even after I enter the security code. Normal phone operations are fine, even when the phonebook doesn't synch, in the sense that I can use the BB keypad to dial.
Are phonelists supposed to be stored on the car's hard drive, or are they re-synched every time the phone pairs to the car? If the phonelist is meant to be stored locally, can someone offer some advice on how I can insure that the phonelist is saved, so that I don't have to wait for the synch every time?
Thanks in advance.
-TA
Thanks in advance.
-TA
Uploads every time. No way to automatically store phone list w/ car (that I know of. ) (BTW, I like it that way. I only have ONE phone list to update-- my office computer, which automatically loads to phone, which automatically loads to car.)
Tip: Add full names to entries. Works better w/ voice dialing: "Call John Doe mobile." Most names work on first try. (A few never work.)
Congrats on new car.
My Ride: 2006 530i Sport
Silver Gray - Black Leather - Anthracite Maple
Manual Transmission
Premium Audio
Cold Weather Package
Rear sunshade
Sirius Radio
Autobahnd Roadblock (3M) film kit
I think the BB is encrypting the phonebook info, and it's not accessible until you enter the access code. I had the identical thing happen on my WinMo phone when I had full crypto on it.
If there's a way to make an exception in the phone or BES for the phonebook - in other words, making the data accessible without having the security PIN entered, that would be ideal.
My Ride: G30 M550i
Model Year: 2018
To further elaborate on what UUronL is saying, you need to go to the BlackBerry and choose "Settings", then "Options", then "Bluetooth." Once there, highlight the entry for your car (it'll likely say "BMW xxxxx") and choose "Device Properties." Find where it says "Trusted" and make sure it's set to "Yes" (the default is "No").
Good luck!
Good luck!
Manual Transmission
Premium Audio
Rear sunshade
Sirius Radio
Good luck!
Good luck!
Actually, I re-read his original post and modified my response. I think this is an issue with how the Blackberry is permitting access to sensitive data (the phonebook) when it's on "lockdown".
My Ride: G30 M550i
Model Year: 2018
Unless his security code is something managed at a corporate (BES) level, I don't think that's the issue. My BB is set to automatically lock after a specified time so I also have to enter an unlock code to use the handset. The car always pairs and the phonebook is available right after pairing even when the handset is locked. In addition, when the handset is locked, I can still make calls through the car...
Manual Transmission
Premium Audio
Rear sunshade
Sirius Radio
I'm thinking it's likely corporate BES policy then. Like I said, I had the identical issue with my WinMo handset after installing full-handset crypto. I had to add exceptions for the phonebook data in the crypto app, otherwise the phonebook wouldn't sync unless the phone had been unlocked via the passcode first.
BB has full-crypto by default as we all know.
I actually found this after a quick search which is exactly what I thought:
http://www.blackberryforums.com/general-bl...rry-locked.html
My Ride: G30 M550i
Model Year: 2018
On my last two BlackBerrys, neither of them on BES, the phonebook was available via iDrive even when the phone was locked. I never enabled the "allow outgoing calls while locked" feature and I'm pretty sure that the only thing you can do with my phone while it's locked is answer an incoming call (and probably call 911).
So unless there's a corporate policy getting in the way for the OP (or unless I'm completely misunderstanding things here) it may very well be something as simple as setting the phone to trust the car on future pairings...
Manual Transmission
Premium Audio
Rear sunshade
Sirius Radio
Originally Posted by Rudy' post='1001345' date='Sep 7 2009, 10:59 PM
It's funny but in that thread you linked to, the OP said he wasn't on BES. I'm not too sure what's going on with our OP but here's what I do know...
The thread says no BES, and it also says they disabled encryption on the phonebook, but those guys seemed pretty certain that scrolling through the phonebook would be impossible. It's clearly something tied to how the BB is securing the data to prevent "leakage". I can't explain your good luck with things, but I've found a lot of other similar posts on various forums as my search continued.
Also, are there multiple levels of "lock" on the BB? Perhaps a keypad lock that doesn't secure much, and then a device PIN that secures much deeper?
