Phone unable to connect
My Ride: 2005 525i
Hi I just recently got a 05 525i from my mom I enabled bluetooth through the idrive but every time I try to connect it says unable to pair anyone have this issue my phone is a galaxy s6 with android 6.0
Thanks
Thanks
I'd recommend that you clear all of the previous phones out of iDrive. Have your phone "forget" the BT connection with the car. Then, re-start the pairing process.
My Ride: 2005 525i
Ok so the car has never had a phone connected to it I'm the second owner and my mom was the first and she never used it I'll keep trying but I haven't had any success I've tried three different phones
My Ride: 2005 525i
Ok so trying again now I have an iPhone 7 still no luck is there a specific pin for each car or is it generic? Really frustrating would like to use the cars Bluetooth capability
My Ride: 530i
Engine: M54
There should be a bluetooth snap-in adapter under the center console lid, it looks like a computer mouse with a small blue LED light on it.
the bluetooth PIN is on the underside of the adapter. you need to remove it and get the PIN. also, make sure the adapter is seated properly. if it is, press the small button/LED light thats on the top of it to start the pairing process. if you don't have the snap-in adapter at all, there's your problem.
good luck.
good luck.
My Ride: 530i
Engine: M54
you can get them on Ebay. check realoem.com to get the correct part number you need. welcome to the wonderful world of BMW, where everything is more complicated than it should be. happy shopping
