Nokia N72
My Ride: 520d
Hey there,
Got a small problem here :
I paired a new nokia N72 to the my 4 months old 520d (2007). Can make calls, but no phonebook transfer...
Anyone have a solution?
Second problem : phone does not connect automatically, must make the connection manually every time.
Any ideas? I think all the setting are just fine...
greetz,
Ribo,
AND A HAPPY NEW YEAR !!!
greetz,
Ribo,
Originally Posted by Ribo' post='372644' date='Dec 31 2006, 09:14 PM
Hey there,
greetz,
Ribo,
greetz,
Ribo,
Is phone authorised to connect automatically ?
bluetooth settings/paired devices
no help with phone book
550i & Nokia E61
My Ride: 520d
550i & Nokia E61
550i & Nokia E61
Yes, the phone is authorised, and yes, they have paired...
That there will be no phonebook transfer, I can live with that... But I'd like to recieve calls in car without having to connect manually every time...
Anyone a solution?
Oh... and I posted in the wrong subforum. Please move.
Greetz,
Ribo
Anyone a solution?
Greetz,
Ribo
Anyone a solution?
Greetz,
Ribo
connectivity/bluetooth. then choose "paired devices" submenu.
you should see BMW **** there, scoll (but dont click) to BMW, then
choose options and select "set as authorised".
it must work, i had zillion nokia phones and all of them
connected without any problem. 6230i transfers phone book.
My Ride: 520d
Originally Posted by mirage.za' post='372772' date='Jan 1 2007, 08:18 PM
I think you missed my point - you must go into :
But in the meanwhile the problem solved itself.
Sunday I tried and tried, starting up the car, putting the N72 on and off... just no automatic connection.
And... surprise, surprise... today it just connected !
But I doubt there will be a phonebook transfer.
Anyway, thanks for the response !
Greetz
On my N93 there's an option under bluetooth settings called "external sim mode" (or something like that, mine is set to Dutch).
You need to enable this to share the phonebook.
I don't know if this option is available on the N72 but the default setting is 'off' so it's worth giving it a try .
My Ride: Jet Black 2007 E60 550i
-Sport Package
-Comfort Access
-Navigation
-Logic 7
I'm in a similar situation. The car recognizes my phone but I can't make or receive calls on it. I'm using a Nokia N73
My Ride: 2007 BMW 550i w/SMG - JetBlack - Dinan Software - Dinan Exhaust - Anthracite Trim - Anthracite Headliner - Sport Package
My Ride: 545i SE Oct 03 (53 plate) 19" Alpina Classic rims
I have a Nokia N73
You can transfer the phone book by going to the nokia contacts menu and mark all contacts. you can then send them by bluetooth to the vehicle. (be sitting in the car with the ignition on after pairing.)
It worked for me
ps - it may seem like it hangs on transfer, just give it a few minutes and then ignition off and back on again and the contacts will be in the idrive.
pps - to auto connect go to your bluetooth setting on your phone, select the paired device and you should have a option called authise or 'trusted'. Selecting this will make the phone auto connect.
It worked for me
