Nokia Bluetooth...
My Ride: 2011 550 AW
2005 530AW GONE
Has anyone had success with a nokia bluetooth phone. I have a 6600 and tried and tried. It will pair, but I drive also ask me to activate phone...Huh??
My Ride: May 2004 525 Amethyst grey, Heated front seats, bluetooth prep, Adaptive Xenons, 6 CD changer, Front & Rear PDC, retro-fit 6 DVD changer in boot (trunk) with remote control plus headrest screens and IR headphones, Playstation connection to cabin, twin 12v outlets in rear cabin
My 6310i works fine, every time.
My Ride: 530d, 2004, full option.
I have a nokia 9500 comunicator and works just fine with BT.
The only problem is that you have to transfer all the contacts one by one.
Guest
Posts: n/a
I have the same problem as Brae60 - but with a Nokia 6820.
The pairing worked fine, but the Phone menu still says "Please activate phone"
Strangely enough, all calls made on the phone do go through the car as they should....but I can't use the steering wheel buttons to initiate any calls and I don't have access to the contact list.
Also, I don't have a nav system (no voice button next to the iDrive button). Does that mean I can't use the Voice command button on the steering wheel either?
-Navin
-Navin
[snapback]81411[/snapback]
./sherif
Originally Posted by Breae60' date='Jan 20 2005, 10:47 AM
Has anyone had success with a nokia bluetooth phone. I have a 6600 and tried and tried.? It will pair, but I drive also ask me to activate phone...Huh??
[snapback]81112[/snapback]
Here - This is getting easier. If the phone is on this list of Bluetooth Qualified models, it will work with the E60 properly.
http://www.bluetooth.com/products/prods.as...4&go.x=6&go.y=7
If not, check here:
http://x5world.net/2005_bt_pairing.htm
My Ride: 2001 BMW 316ti, 2004 BMW 530d, 2006 BMW 530xd, 2013 BMW 320d touring, 2014 BMW 520d touring, 2016 BMW X5, 2020 BMW 320da touring, 2020 BMW 540i
Model Year: 1974
Engine: Flat six
I have tried to pair a Nokia 6600 with my BMW and it wasn't possible.
I have at the moment two phones connected, a SE T610 and a MOTOROLA V550. Both of them are working fine.
The 6600 wasn't possible to pair, i tried several times, the car recognises the phone but the problem is in the phone that won't let the connection to work. It says something like " ...Device not compatible..."
But that's only my personal experience, maybe your 6600 could have a different software and let the connection to work.
2005 530AW GONE
[/quote]
You need to put the passkey into both devices to pair.
If not, check here:
Not to burst your bubble, but just because the phone has bluetooth does not mean it will work with the E60's BT. Not all BT speak the same lingo, as I have learned, BT in BMW is made by Motorola, thus, mainly Motorola and Siemans works best with some SE models too. Nokia are not fully functioning with BMW BT.
If not, check here:
[snapback]84782[/snapback]
[/quote]Not to burst your bubble, but just because the phone has bluetooth does not mean it will work with the E60's BT. Not all BT speak the same lingo, as I have learned, BT in BMW is made by Motorola, thus, mainly Motorola and Siemans works best with some SE models too. Nokia are not fully functioning with BMW BT.
