Nokia 9500 Communicator and BMW Blue Tooth
Well,
Some good news. I got a new Nokia 9500 communicator. Paired very nicely with the BMW ULF. No problems whatsoever in pairing. Used it for a few calls entering numbers on Idrive. No problems. Call quality is great. Voice control works. Incoming calls show number on Idrive screen.
Only thing missing is phonebook sync. Tried for a few minutes. No go. Switched phonebook to SIM, still no go. Will try sending the phone book manually later today and update this post.
Overall a very encouraging start for using this phone with BM BT. If anyone has similar experiences please let me know.
A very god source of info and hope for possible future fixes is the Nokia 616 BT carkit which works in a very similar fashion to BMW BT.
./sherif
./sherif
Originally Posted by Sherif' date='Dec 9 2004, 05:56 AM
Well,
./sherif
./sherif
[snapback]66939[/snapback]
Hormazd,
I actually tried it with just two contacts in each book. I left it for quite a while and still no go. I tried sending those contacts manually. Still no go. I might be doing something wrong with the manual send. have you done this before? Can anyone provide some detail about sending the phonebook manually. I might be missing something here.
./sherif
./sherif
Originally Posted by Sherif' date='Dec 10 2004, 01:48 AM
Hormazd,
./sherif
./sherif
[snapback]67386[/snapback]
Are you sure your Egyptian manufactured BMW has the right software version and ULF?
Hormazd,
The car is a locally assembled E60. From what I have seen the bluetooth is a ULF module that has worked flawlessly with the included Nokia 6310i and K700i. Idrive version is not mentioned anywhere on the car. However, I believe it is a very recent version since most of the new features discussed here on the forum as new have been in the car from day one. Even some of the issues people have been complaining about such as five rings with BT etc.. have not shown up on my car. The reason I was asking about the manual transfer is that the phone book has not shown after pairing. Everything else works. I checked the BT compatibility page on x5world and some phones mention that they only work with manual transfer, that's why I was asking so I can try this approach.
./sherif
./sherif
Sherif,
I honestly have no experience with the Nokia 9500. I was just comenting that it took a a while for the address book to transfer using my V3 RAZR. This happened when the phonebook was on the phone and not the SIM. You should not make calls or look at the phone screen for half an hour while the phone is paired. I think if the Nokia 9500 is compatible, it will transfer. Also put them all on the phone. If one has a problem, it might block the process for the other. I have the ability to move the entire book on and off the SIM.
Hormazd,
Thanks. I'll try again tomorrow and keep this topic updated. You mention half an hour, how many contacts did you have on the phone. Are you aware of the limit on the number of contacts that the ULF memory can hold??
./sherif
./sherif
Originally Posted by Sherif' date='Dec 11 2004, 02:00 PM
Hormazd,
./sherif
./sherif
[snapback]67959[/snapback]
TroyE60
05-30-2019 05:01 PM
