New Service Bulletin for BT retrofit
My Ride: MY 2004 545i; April build; 6 speed; silver grey metalic; black leather; poplar; sport package; cold weather; active steering; xenons .
Originally Posted by pbarch1' date='Jan 18 2005, 05:27 PM
This is wonderful for all you with 3/04 or later production cars .... but what about us poor schmucks that bought our E60's at roll out, I guess we are just screwed .... AGAIN
[snapback]80493[/snapback]
Guest
Posts: n/a
My 11/03 build came in with a BT passkey. Delivering the passkey certainly shows the intention of BMW to have BT available even if it was not available at that stage. All pre-Sept 2004 E-60 owners: Shouldn't all pre Sept 2004 be covered under warranty?
Originally Posted by Guest' date='Jan 18 2005, 04:01 PM
My 11/03 build came in with a BT passkey.? Delivering the passkey certainly shows the intention of BMW to have BT available even if it was not available at that stage.? All pre-Sept 2004 E-60 owners:? Shouldn't all pre Sept 2004 be covered under warranty?
[snapback]80507[/snapback]
Originally Posted by beemerfan' date='Jan 18 2005, 06:02 PM
[quote name='Guest' date='Jan 18 2005, 04:01 PM']My 11/03 build came in with a BT passkey.? Delivering the passkey certainly shows the intention of BMW to have BT available even if it was not available at that stage.? All pre-Sept 2004 E-60 owners:? Shouldn't all pre Sept 2004 be covered under warranty?
[snapback]80509[/snapback]
[/quote]I agree with your analysis of the significance of the inclusion of the passkey card. They should upgrade the software, and replace the TCU if necessary, to make the BT work under warranty. Yesterday, I got my car back from the dealer after the completion of the emissions upgrade. They used my info regarding the BT bulletin to fix the BT. I didn't need a TCU. They didn't charge me for the BT repair. I got a BT phone last night, did the pairing procedure and it works.
Defndr: Congratulations! We were at our respective dealers at exactly the same time, for the same 2 reasons. Which phone did you get? My dealer already had the procedure and when I go to communications, it says "Activate Phone".
Sam
Sam
Originally Posted by widjajachandra' date='Jan 19 2005, 03:37 PM
How much we are looking for if the dealer activate it?
[snapback]80820[/snapback]
Originally Posted by sj3' date='Jan 19 2005, 12:03 PM
Defndr:? Congratulations!? We were at our respective dealers at exactly the same time, for the same 2 reasons.? Which phone did you get?? My dealer already had the procedure and when I go to communications, it says "Activate Phone".
Sam
Sam
[snapback]80741[/snapback]
Originally Posted by dfndr' date='Jan 19 2005, 03:49 PM
[quote name='sj3' date='Jan 19 2005, 12:03 PM']Defndr:? Congratulations!? We were at our respective dealers at exactly the same time, for the same 2 reasons.? Which phone did you get?? My dealer already had the procedure and when I go to communications, it says "Activate Phone".
Sam
Sam
[snapback]80888[/snapback]
[/quote]Nothing until April, when I can upgrade. Since I'd like Palm integration, the Treo 650 is all there is, on Verizon. Hopefully there will be something new out by then but I think the 650 can be hacked to get around Verizon's lockout.
Sam
