I need help pairing my new phone.
I recently got the Samsung Galaxy Note. The was able to pair my GNote normally. I could view my phone book through idrive and able receive phone calls. However when I try calling someone through idrive it just goes no where. (I click on call and it blinks that all). The only way to call someone is through the phone and then I could use the car Bluetooth. Has anyone had the same problem? |
you must check the settings of your cell phone bluetooth and then the settings of your car. if there is no prob in it, then simply unpair then and again pair them. and u must check the settings of your bluetooth from your cell that either any timer is set for the visibility ...
