Is my car bluetooth ready?
Old 06-25-2009, 06:24 AM
whonneb's Avatar
Originally Posted by JD94534' post='884980' date='May 20 2009, 08:46 PM
+1 same here. The dealer updated the software on my 04 545 build on 05/04 and the Bluetooth paired to my I-Phone. Once you check the software in the car make sure your phone is compatiable with the ones BMW has tested. This way you will know if the phone you want to use will work or if you need to get a new phone.
http://www.bmw.com/com/en/owners/navigatio...troduction.html
Did you guys just go to dealer to get this done?
Old 06-25-2009, 06:31 AM
theXman's Avatar
My Ride: 2004 530i
The simple answer is "yes". But you should do some research and know about your car's BT capability first. For the earlier production years E60, it might require both an updated TCU unit and software upgrade in iDrive. As the later models require only software upgrade. Good luck!
Old 06-25-2009, 06:39 AM
whonneb's Avatar
ok, my car has production date of july 04, how else can I tell?
Old 06-25-2009, 06:49 AM
theXman's Avatar
My Ride: 2004 530i
Check the TCU unit in the trunk. Please my post above (#5).
Old 06-25-2009, 06:55 AM
pjinca's Avatar
See what happens here? Now I am going out to the parking lot and tearing apart my trunk at work, thank Xman!!
Old 06-25-2009, 07:16 AM
whonneb's Avatar
my tcu didnt have any stickers on it, however I did find a motorola box that was sitting on the drivers fender well
It had the numbers 84.21.6919520-02 232925 21 usa.
Does that mean I am all set?
Old 06-25-2009, 07:23 AM
whonneb's Avatar
I called the dealer and they gave me the tcu.
tcu - 14602385227
Old 06-25-2009, 07:27 AM
theXman's Avatar
My Ride: 2004 530i
Not sure what the motorola box is. But take a look here (http://forums.e60.net/index.php?showtopic=71179, post #13), the metal box closer to the backseat is the TCU unit. And it should have a sticker similar the one in post #22 with production date.
Old 06-25-2009, 07:36 AM
theXman's Avatar
My Ride: 2004 530i
My guess is since your E60 is post 3/04 production, it should only require software upgrade.
Here is another link with a BT pdf in post #1. http://forums.e60.net/index.php?showtopic=61510
Hope this helps.
nmc
10
05-15-2016 07:07 PM
Godzilla
04-13-2015 05:47 AM
Quarta2six
04-03-2015 07:32 AM
JonathonK
03-27-2015 08:13 AM
Woodstock
12-10-2003 02:21 AM
Quick Reply: Is my car bluetooth ready?
