Microphone cable reroute
Hi
Im doing a NBT retrofit and i need to tap into the microphone cable, Bimmerretrofit manual says to go from the MULF unit wich is kinda far considering the mic is in the front. Anyone out there done the bluetooth retrofit that can tell me where the best place is to tap in? |
So i just went ahead and disconnected the mic cable from the MULF, from there i found out it went up to the roof and then to the MIC.
So after i managed to get it loose from the other cables i then took it down the A pillar and into the Head unit.. |
