Gateway 500 problem
My Ride: 530 2005 E60
Hi all.
i Got my GW500 installed yesterday after a software upgrade.
today i was back to the BMW dealer and had the Ipod retrofit and Phone ready installed in the car.
No i got
DVD CD CD1 CD2 CD3 CD4 CD5 CD6
but i cant choose the CD1,2,3,4,5,6
i have updated the firmware in teh GW500 by the USB and it worked like a charm. the file is gone afterwords (Wich is supposed to)
i got a E60 2005/04-29
Big navi.
The BLT is not shown eighter in the phone menu.
i have checked the pins on the GW600 they are 2upp and the last one is up
i have no CDC in the car.
so the GW is supposed to be installed like 3A acording to the manual
Anyone that have aclue on that it can be?
Im sitting in the car and my laptop is running out of battery :-(
No i got
Big navi.
My Ride: '04 530d Executive, all options except sunroof and comfort seats
ECU remapped by ZipTuning to 260+bhp.
I had some problems getting the car to detect the GW500 too.
I have the CDC, so i connected it differently.
Make sure you have enabled the MP3 and CDC options by the dealer. (Not only iPod retrofit, insert a MP3 CD-ROM into the audio-disc drive to test the MP3 option!)
Also, connect the small box that comes with the gateway and has the RCA plugs on it (for AUX connections). Reset the fiber-optic ring with the little hole on top of that box.
Make sure the "pass-thru" button is not pressed on that box too.
Bluetooth is a completely different problem, but it will only work if you've got the BTA1500 add-on AND disable the TCU (i've created a topic on this).
it works fine with the MP3 cd so the MP3 option is working just fine.
the box with the RCA plugs is installed and there is a blue lamp (Steady shine= its in GW mode)
i have tryed to reset the bos (In the small hole aswell)
The cars here in Europe dont have the TCU from the factore only you guys who is so lucky :-)
But i think the BLT1500 will work as soon as the GW is working :-)
Originally Posted by X3MKing' post='1004266' date='Sep 11 2009, 12:27 AM
Hi thanx for the answer.
Basically: If you have a phone in the armrest and/or have the SOS button, you have a TCU.
(Rip out the trim on the left side of trunk to find it)
To get your bluetooth to work, you HAVE to disable the TCU, otherwise it just won't work properly.
Are you trying to connect your GW with or without the BTA1500 attached?
Originally Posted by OverSoft' post='1004286' date='Sep 10 2009, 07:05 PM
Well, i'm from Europe too and i had a TCU
No i dont have a Phone in the armrest and no SOS button.
im tying to connect with the BLT1500 Attached
Originally Posted by X3MKing' post='1004621' date='Sep 11 2009, 07:45 AM
Ahhh oki.
Originally Posted by OverSoft' post='1004697' date='Sep 11 2009, 03:56 AM
Try it without the bluetooth module first. It can save a lot of headache.
Originally Posted by X3MKing' post='1004845' date='Sep 11 2009, 11:06 AM
tested now without the blt1500 still nogo :-(
Just been to the guy who installed it and also spoke to Dension Sweden and they spoke to the guys in england.
it MIGHT be that the guy (supposed to be a profesional) has installed it wrong
So he will pick upp my car on monday.
Hold your thumbs now :-)
Or you can wait until monday.
Now monday is over and Guess what.
IT WORKS Tjohooooo
BUT.
How can i get my phone up in the BMW original menu?
If i use the bhone and makes a call i got the option to call with the dension blt
and also if i recive a call i can choose to answer on the Dension BLT.
But how do i get it up in my car :-) ?
http://www.automob.ca/common/SiteMedia/GAT..._%20March08.pdf
just looking at compatability chart here
am i right in saying that e60 with idrive mask head unit is compatible with the dension?
