Cell phone for E60
Hello, can you share some expirience and tell me, i need to buy phone for my E60 but i am not sure what works the best, i dont need any fancy mobile, some normal nokia or anything, so can you tell me whitch is best for that part of using, i am planing to buy some normal phone for it, nothing fancy
Thanks
Thanks
My Ride: E60 M5, F85 X5M
I'm not sure why you're worried about which phone is best with the car cause you probably use it more when you're not driving so get a phone that has the options/specs that suit your needs. You also have to find the right carrier and plan too which may dictate which phones you can get. I believe any phone with bluetooth should be able to be paired with the E60.
Aljosha,
the black thing in which the phone sits is called a "cradle insert".
there are various cradle inserts available from BMW, but your cradle insert only fits one specific phone.
if you want to use your cradle, you have to check at BMW dealer for what phone it is made.
but the cradle is not so good for use, as it only charges your phone and helps with the reception a bit. if you have a separate charger, you basically dont need the cradle.
do you have Bluetooth on your car and do you want to use it?
Thanks
Thanks
You need to complete your profile to make it easier get answers to questions about features and functions specific to your year and model BMW.
My Ride: 530I Silver gray with gray leather with Premium Package, Logic 7 Premium sound system with Ipod interface, xenon adaptive headlights, Active steering, Power retractable rear sunshade, Comfort seats, Cold weather package and M5 OEM 166 wheels, Sprintbooster. Ceramic Tint all around, Bilstein Sports shocks with Eibach springs, Brake performance Rotors and Axxis ceramic pads.
If you have bluetooth in your car, I doesn't make sense to have the cradle. It is one additional thing you need to do when you get in the car. As far as charging your phone get a lighter connect charger.
Model Year: 2010
I do not have a cradle, but a cradle provide a single docking location for: no unsightly cable(s), power source, multimedia connectivity, and external antenna connection (better reception).
