Can Two phones be paired to E60?
My wife and I both have Moto Razr v3. Her phone pairs up fine but my phone "can't find the device".
I have not try deleting her phone and try to pair mine. Has any has more than one phones paired to the E60.
Thanks.
Thanks.
Yep. I have three (Nokia 6820, 6234, and Blackberry 7239). All working as advertised (i.e. different degrees of compatibility).
My Ride: G30 M550i
Model Year: 2018
You can pair more than one phone but only one can be "active" at a given time. If your wife's phone is active, then your phone may not be discovered. Make sure to turn hers off when you attempt to pair yours -- once you get them both paired, you can set the priority in iDrive to choose which phone has precedence over the other if both are available...
I believe the bluetooth on her phone was off when I tried to pair my phone. I'll give it another shot with the other phone completely turn off when i get home later tonite. Thanks for the advice.
My Ride: 2006 530D SE; Mystic Blue; Beige Leather; Luxury Pack; Media Pack; Visibility Pack; 123's; Logic 7; + to many more to type...........
2008 730D; Black Sapphire; Cream Beige Leather; plenty of options!
Thanks.
Thanks.
I regularly use two telephones, a Motorola Razr V3i and Siemans S65 - both paired with the car, the Siemans is the priority (top of list) - All I do is turn on/off the V3i bluetooth to switch between - its simple to setup/do on the V3i as you can set an icon to access bluetooth menu (I also switch the Siemans off), when I switch from one to the other - you don't need to set priority via iDrive either as the car will link to the active bluetooth telephone - I'd say therefore if 'either' (not both) your wives or your telephone has the bluetooth switched on (e.g. power set to on under V3i Setup) the car will automaitically pick the telephone with the enabled buletooth, this would allow for a simple means for either yours or your wives telephone to be active in the car, try and hope for the best ..............
bruce_miranda
04-15-2015 03:25 AM
