BT keeps car from going to sleep
Recently, I have had a battery drain problem where the car will be completely dead when I go to start it in the morning if it has not been driven for >9 hours or so.
I took it to the dealer who could find nothing wrong with the car and left it over the weekend. They had no problem starting it up.
It turns out that I normally keep a bluetooth-enabled SE T610 in the car, turned on at all times, but did not leave the phone with the dealer. I mentioned this to the Service Manager as the only thing I could think of that was different between what I normally do and what they did.
He talked to the tech working on the car, who is knowledgeable about the way the BT system works in the E60 and he said that leaving the phone on when the car is turned off would definitely keep the car from going to sleep, and eventually would drain the battery.
Has anyone else experienced this?
This is also a warning to other BT users, not to leave your phone on and in the car overnight. After three weeks with a new battery, this would drain it flat in 9-10 hours.
My Ride: E90 M3
Model Year: 2011
I'm glad to hear they seem to have resolved your battery drain issue! Have you had a chance to test it by taking the phone out of the car at night to see if the battery drain stops? Or I guess the dealer did not have the drain issue since the phone was with you. Good tip for those w/ BT!
My Ride: Born Date 9, 1 2004. 2005 530i, silver gray, steptronic, nav, Adaptive xenon, premium pkg, cold weather pkg, premium sound pkg, Euro rear reflector. MP3 Enabled
I took it to the dealer who could find nothing wrong with the car and left it over the weekend.? They had no problem starting it up.
It turns out that I normally keep a bluetooth-enabled SE T610 in the car, turned on at all times, but did not leave the phone with the dealer.? I mentioned this to the Service Manager as the only thing I could think of that was different between what I normally do and what they did.
Has anyone else experienced this??
This is also a warning to other BT users, not to leave your phone on and in the car overnight.? After three weeks with a new battery, this would drain it flat in 9-10 hours.
[snapback]93533[/snapback]
Soon as I turn off my engine, my phone status shows bluetooth disconnected..
Is that means that bluetooth is disabled???
Or is this depends on phone?
Originally Posted by uukahn' date='Feb 24 2005, 01:36 AM
[Glad see you have resolve your problem. .. but I am thinking how this can be possible.
Is that means that bluetooth is disabled????
[snapback]93787[/snapback]
Not sure whether it's phone dependant or not. I assume if bluetooth is left on in the phone, it continuously "pings" to find a pairing and this is what keeps the car from fully going to sleep. My T610 has a "power save mode" for the BT handsfree. At some point, I may experiment to find whether that solves the problem.
I have a SE T637 and have left the phone on in my car overnight many times. Never once had an issue. When I turn off my ignition, my phone indicates that the BT connection has been lost and then goes into a sleep mode. Is it possible that it may be your phone settings?
Originally Posted by ademitt' date='Feb 24 2005, 01:44 PM
I have a SE T637 and have left the phone on in my car overnight many times.? Never once had an issue.? When I turn off my ignition, my phone indicates that the BT connection has been lost and then goes into a sleep mode.? Is it possible that it may be your phone settings?
[snapback]93930[/snapback]
The only setting I can see in the phone which could make a difference is in the Handsfree Options menu under bluetooth. There are two choices: Always On and Powersave. I've had it on Always On and was going to try Powersave to see if it makes a difference.
Originally Posted by rfg17' date='Feb 24 2005, 03:11 PM
[quote name='ademitt' date='Feb 24 2005, 01:44 PM']I have a SE T637 and have left the phone on in my car overnight many times.? Never once had an issue.? When I turn off my ignition, my phone indicates that the BT connection has been lost and then goes into a sleep mode.? Is it possible that it may be your phone settings?
[snapback]93940[/snapback]
[/quote]The only way I can think that could happen is if you were in the middle of a call when you shut your car off, I believe you can continue to talk until you disconnect the call. That being said, if your phone says Bluetooth connection lost, it can't possibly affect the vehicle and prevent it going to sleep. Do you have the snap in adaptor for the phone? If so was the phone left in the cradle when this happened?
Originally Posted by Bluetooth Fairy' date='Feb 24 2005, 04:42 PM
The only way I can think that could happen is if you were in the middle of a call when you shut your car off, I believe you can continue to talk until you disconnect the call.? That being said, if your phone says Bluetooth connection lost, it can't possibly affect the vehicle and prevent it going to sleep.? Do you have the snap in adaptor for the phone? If so was the phone left in the cradle when this happened?
[snapback]93990[/snapback]
As the service guys said, the systems are complicated and can interact with each other in strange ways, which drive THEM crazy as well as us.
