BMW Bluetooth Setup
My Ride: 2004 545i 6spd Man, 19' Breyton Wheels, Ipod Install, Parrot Bluetooth, AC roof and Trunk Spoiler
Today I install my CPT9000 Bluetooth Module but when I go to communication screen it keep telling me to contact bmw. have anyone ever installed a CPT9000 without issues ?
i assume that it was just installed outside bmw dealers... if that is the case, you need to bring the car in to have software update and to have the phone option activated by them... remember, not Bluetooth option, but the cpt9000 setup... that way, everything should be functioning correctly....
good luck
cheers
good luck
cheers
Originally Posted by Almighty JungleBoy' post='536582' date='Feb 27 2008, 03:42 AM
good luck
cheers
good luck
cheers
When I got my Ipod Interface installed, the software was updated to CIP 28, I thought that would also activate everything . I guess I have to bring it in and spend more $$$.
You didn't answer my question, as to whether the CPT phone was working prior to installing the BTUM. If you want help here, you need to provide more info.
There is no CIP28, you would have gotten Progman 28. CIP ended at CIP 19.
I'm trying to figure out how come the car then has the base for the CPT9000 phone if there was no phone.
I don't recall that cars came equipped like that.
I take it you didn't order the CPT9000 phone originally but did you install the cradle?
if you did plug everything properly in the armrest, then they have to activate the CPT9000 and must remove the Bluetooth option in the setup menu... otherwise, they will both conflict... the car would get confused with both CPT9000 and Bluetooth TCU setup in the car... it is either one or the other... if you are using BTUM, they must update the software patch for the car to recognize your CPT9000!!
TroyE60
05-30-2019 05:01 PM
chadillac2000
42
09-13-2017 11:15 AM
