Bluetooth stopped working
Old Apr 1, 2005 | 02:29 AM
GER_545SMG's Avatar
All of the sudden my bluetooth connection has stopped working. When I go to the communications screen all I see is Please Activate Phone, which I believe was the case before I got bluetoth activated. The software was updated when the car was in for service back in December. I've rebooted my phone, restarted the car obviously, I've gone through device discovery in the bluetooth menu in the phone, but nothing has worked.
Has anyone seen this before?
Old Apr 1, 2005 | 02:37 AM
MZGUY's Avatar
I wish I could help you. I picked up my 545 yesterday and cant get my phone to work at all. I am taking today off of work just to get my car right. If I learn anything at all, I will let you know.
Old Apr 1, 2005 | 03:34 AM
andy545's Avatar
Model Year: 2005
Engine: 545i
Originally Posted by GER_545SMG' date='Apr 1 2005, 12:29 PM
All of the sudden my bluetooth connection has stopped working.? When I go to the communications screen all I see is Please Activate Phone, which I believe was the case before I got bluetoth activated.? The software was updated when the car was in for service back in December.? I've rebooted my phone, restarted the car obviously, I've gone through device discovery in the bluetooth menu in the phone, but nothing has worked.
[snapback]109746[/snapback]
Happened to me once. The bluetooth just didn't want to 'see' my phone. I had to go through the initial pairing procedure several times, before it decided for no apparent reason to work fine again. Apart for that small hickup, no other problems.
Give it another go.
Old Apr 1, 2005 | 03:56 AM
Guest
Guest
Posts: n/a
What kin dof phone are you using? Try dropping the connection from the handset and connecting again. If this does not work....delete the phone from the iDrive and repair. Also, check you SIM or phonebook in your phone. Make sure that entry 1 is not just a number but has a name associated with it. Also make sure that in the name that is associated with the first number in your phone book does not contain any special characters. ie. *,/,# etc. This will cause the phone to lose connectivity under certain cases.
Old Apr 1, 2005 | 03:57 AM
ledbettm's Avatar
My Ride: On order: 2007 550i, silver gray, black leather, anth. maple trim, active cruise, heated steering wheel, sport, night vision, vent seats, heat rears, active steering, rear air bags, folding seats, comfort access, navigation , HUD, black head liner, steptronic, premium sound, sirius and HD radio.
Sorry that was me.
Old Apr 1, 2005 | 04:27 AM
Olivin530i's Avatar
Same happened to me once. Delete the BMW b/t profiles on BOTH the mobile phone and in iDrive. Re-discover and re-pair the devices and it should be fine after that
Old Apr 1, 2005 | 12:39 PM
GER_545SMG's Avatar
Originally Posted by Olivin530i' date='Apr 1 2005, 06:27 AM
Same happened to me once.? Delete the BMW b/t profiles on BOTH the mobile phone and in iDrive.? Re-discover and re-pair the devices and it should be fine after that
[snapback]109780[/snapback]
I can't see where to delete the BT profile on the 5 now? It just says Please Activate Phone, and gives no other option to do anything else (It just says Phone and BMW Service at the top o the screen). It almost seems like it was before i got the car re-coded with BT enabled...
Is there another screen I need to navigate to?
Old Apr 1, 2005 | 01:37 PM
sapaman's Avatar
Originally Posted by GER_545SMG' date='Apr 1 2005, 05:39 PM
[quote name='Olivin530i' date='Apr 1 2005, 06:27 AM']Same happened to me once.? Delete the BMW b/t profiles on BOTH the mobile phone and in iDrive.? Re-discover and re-pair the devices and it should be fine after that
[snapback]109963[/snapback]
[/quote]
imenu --> Communication settings --> Bluetooth
Old Apr 6, 2005 | 09:32 AM
gdavis's Avatar
I've been trying to pair a new phone and I've gotten to the same point without getting the connection.
then I see the car's ID in my phone, and the iDrive setting asks for a passkey, which I made up, but it seems like I'm doing something wrong, 'cause the phone doesn't give me further choices as 'Done'
and then the phone times out and says 'unable to connect'
Any know what I'm doing wrong?
(I thought maybe the phone needs a passkey, but could find no place to set one in the phone--- moto razr v3)
Old Apr 6, 2005 | 10:44 AM
gdavis's Avatar
Does anyone know Bluetooth pairing steps in detail?
