Bluetooth and SE T610 problems
<span style='font-size:14pt;line-height:100%'><span style='font-size:14pt;line-height:100%'>I have a new E60 2005 Yesterday. Sapphire Black Metallic/Beige Dakota Leather. While at the showroom the salesman installed the T610 SE and worked well.
While driving home i tried to use it and i experienced some problems, so i tried to do the same procedure again at home but is failing at the process where i key in the passkey code.
Anyone knows how to overcome this?[/S IZE]</span></span>
How do you define what the passkey is? Is it the same on the phone and on the car?
Please help
Please help
I don't have BT, but from what I've read on this forum, the passkey is any 4 digit number that you chose so long as you use the same 4 digits for the car and the phone.
My Ride: Now Driving a Freakin' Prius!
Was...
2004 545i | SMG | White/Black | Sport | NAV | Logic 7 | PDC | Fold-down Seats | Adaptive Headlights | Cold Weather Pkg | Clear-again Bra | Mud Flaps | Bluetooth | Coat Hangar | Aux Input | All Weather Mats | 18"X8.5" BBS RK w/ Michelin Pilot Alpin's (winter) | New steering rack @ 1.2K & 17K miles| Software V.19.1 | B&B Exhaust (vrrrroooooommm!) <---Click.
In my car I set the passkey. I enter it in the phone first then the car. I found that my phone would time-out if it took me too long to enter the passkey using the idrive.
The passkey I'm using is 6 characters (combination of letters and numbers).
Don't forget to select Accept Passkey (I think that was how it was worded).
Hopefully this helps.
My Ride: 2001 BMW M3
Titanium Silver/ Black
Please help
Please help
[snapback]89042[/snapback]
Was...
Originally Posted by BMWofNashville' date='Feb 11 2005, 11:36 AM
[quote name='CHRIS2005E60' date='Feb 11 2005, 11:08 AM']<span style='font-size:14pt;line-height:100%'><span style='font-size:14pt;line-height:100%'>I have a new E60 2005 Yesterday. Sapphire Black Metallic/Beige Dakota Leather. While at the showroom the salesman installed the T610 SE and worked well.
Please help
Please help
[snapback]89058[/snapback]
[/quote]What if he deleted the device in the iDrive screen, deleted it from his phone and started all over??
Guest
Posts: n/a
Please help
Please help
I have the same phone, albeit a T630 and I had to do the same today. All I did was set the phone's bluetooth option to find device's i.e BMW system at the same time have "bluetooth active" on via comms interface on the screen. When it asks you to add device, key in any number, I use my 4 digit unlock code for the phone. Next switch the phone off and on again and your stored numbers will appear on the screen. Easy eh! hmm!
By the way have you got the cradle for the arm rest? Highley recommend it, the signal is boosted by the cars arial and of course the phone charges on the move, only another ?50 from our German friends.
My Ride: 530i auto, sat nat, 6cd, advanced air con, bt, beige leather, dark poplar, mystic blue, 128 9j/8j, runflats, adaptive hd lts, xenon+wash
Please help
Please help
go to your i drive and get into sysem communications and see if your phone is listed if it is then the phone is already paired
you then need to check the software version your PHONE has, do this by going to bmw.co.uk/bluetooth click on the link and it will tell you what sequence of alpha numeric charecters to punch into your phone to show the software version. see if your version is listed as compatable. If not then a sony ericcson flash centre can update your phone software.
I have a T630 with a software version not shown on bm's site but it is the latest version so they havn't tested it yet- but the phone works perfectly. Just a point of interest if you have two phones paired say yours and wifes and you are both in the car if both phones are turned on then the car pairs with the phone that was last used and you have to go into i drive and change the priority
good luck
Please help
Please help
the pass key is any alpha numeric between 4 &16 digits
the salesman probably used the quickest/easiest/simplest (as they do) either
0000 or 1111 0r 1234
worth a try if you are stuck :'(
Originally Posted by skydiver' date='Feb 12 2005, 11:00 AM
[quote name='CHRIS2005E60' date='Feb 11 2005, 05:08 PM']<span style='font-size:14pt;line-height:100%'><span style='font-size:14pt;line-height:100%'>I have a new E60 2005 Yesterday. Sapphire Black Metallic/Beige Dakota Leather. While at the showroom the salesman installed the T610 SE and worked well.
Please help
Please help
[snapback]89435[/snapback]
[/quote]Well you can drop the BMW from the Device list on your phone. It will be listed as BMWxxxx. xxxx being the last digits of your VIN.
Then start from scratch and choose whatever pin you want. The Instructions are Here
