I had the Bluetooth Retrofit done on my 03/2004 build 530i yesterday, and picked it up today (cost = $260). While everything seems to work well (though it says the phonebook is empty when I try to use voice dial), I noticed that they upgraded my PROGMAN from 13.? to 21.0. Shouldn't they have given me 27.1 or higher?
Is your mobile compatible? I've had the same problem with phonebook, until I retrofitted the Navi-Pro and the problem solved. |
I have a crappy Windows Mobile 5 phone (Samsung SGH-i320N) so while the address book entries all came down, the voice commands don't really work and the car says "Phonebook Empty". I have to get a newer manual to see what the proper commands are. I don't have navigation, so I'm not sure what update would help.
Have you ever had the phonebook feature in the past? |
Originally Posted by nicke60gre' post='516525' date='Jan 11 2008, 06:46 PM
I think that the phonebook is a part of the voice commands which they available with CCC (Nav-Pro)
Have you ever had the phonebook feature in the past? Thanks |
Originally Posted by Jboat28' post='516587' date='Jan 11 2008, 08:36 PM
I'm not sure this is what you need, but when I had BT enabled I had the same problem. I figured out that the command is to say" Save Name" and then follow the promts to save a new phone book name (this is the verbal phone book -not the one download from the phone). When your done with the number just say "Save". Let me know if I'm off the mark here.
Thanks |
Originally Posted by Aestivalis' post='516827' date='Jan 12 2008, 12:16 PM
You're right, I did have to save the names. So that all went pretty smoothly. Now is there really any problem with them giving me an older Progman? I noticed the CD advancing tracks once, but I haven't been able to replicate it. Is there any advantage to upgrading to 25 or higher?
