Bluetooth Retrofit complete - old PROGMAN?
I had the Bluetooth Retrofit done on my 03/2004 build 530i yesterday, and picked it up today (cost = $260). While everything seems to work well (though it says the phonebook is empty when I try to use voice dial), I noticed that they upgraded my PROGMAN from 13.? to 21.0. Shouldn't they have given me 27.1 or higher?
Is your mobile compatible?
I've had the same problem with phonebook, until I retrofitted the Navi-Pro and the problem solved.
I have a crappy Windows Mobile 5 phone (Samsung SGH-i320N) so while the address book entries all came down, the voice commands don't really work and the car says "Phonebook Empty". I have to get a newer manual to see what the proper commands are. I don't have navigation, so I'm not sure what update would help.
Have you ever had the phonebook feature in the past?
Originally Posted by nicke60gre' post='516525' date='Jan 11 2008, 06:46 PM
I think that the phonebook is a part of the voice commands which they available with CCC (Nav-Pro)
Thanks
Originally Posted by Jboat28' post='516587' date='Jan 11 2008, 08:36 PM
I'm not sure this is what you need, but when I had BT enabled I had the same problem. I figured out that the command is to say" Save Name" and then follow the promts to save a new phone book name (this is the verbal phone book -not the one download from the phone). When your done with the number just say "Save". Let me know if I'm off the mark here.
Thanks
Thanks
Originally Posted by Aestivalis' post='516827' date='Jan 12 2008, 12:16 PM
You're right, I did have to save the names. So that all went pretty smoothly. Now is there really any problem with them giving me an older Progman? I noticed the CD advancing tracks once, but I haven't been able to replicate it. Is there any advantage to upgrading to 25 or higher?
umnitza
11-03-2015 02:58 PM
boozooface
Bluetooth & Cell Phone Forum
07-29-2015 06:56 AM
